RV.Net Open Roads Forum: General RVing Issues: Recommend a sealant or caulk
 > Recommend a sealant or caulk
dcason
New York
Posted: 08/22/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Hubby is in the process of scraping away old caulk/sealant on class C...around windows, door, compartments. Anyone have a recommended goo to reseal with? AND what do you actually call it. We can use amazon prime or camping world (15 minutes away).
Donna
Our Blog
JIMNLIN
Oklahoma
Posted: 08/22/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
My all time favorite is Dicor for vertical seams. Other have what they like.
Do a google on the rv sealants and then watch several you tubes from experts like rv dealers/rv repair shops shops/etc.
And follow the sealant mfg instructions.
DrewE
Vermont
Posted: 08/22/19 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
For rooftop use: Dicor self-leveling lap joint compound is the standard stuff. It goes on with the consistency of yogurt, so it's not useful at all for vertical applications (it self-levels down the wall).
For other things, I find OSI Quad Max works fairly well and is not too expensive and is available at big box stores. The Max version is definitely nicer to work with than the standard OSI Quad, and the nozzle on the tubes can be unscrewed and cleaned out after storage should it goober up which is a big advantage as far as I'm concerned. This is a polyurethane-based compound, I believe, not too much unlike GeoCel Proflex.
For little things like door hold-open catches, plain plumber's putty also works pretty well and is comparatively neat and clean to work with and easy to remove should the need come up.
dcason
New York
Posted: 08/22/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. No roof stuff at this time just horizontals and verticals. You mention PROFLEX Geocel and that was what i was just looking at...use that?
Charlie D.
E. Texas-Orange
Posted: 08/22/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Dicor make a non-sag/non-leveling sealant for vertical and horizontal trim.
https://www.amazon.com/Dicor-551LSD-1-No........locphy=9027868&hvtargid=pla-783598772533
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 08/22/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Geocel Proflex is amazing stuff - it sticks to anything. Forever.
rav
Full Timing
Posted: 08/22/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Geocel and one recommended by the factory called Manus bond 75-am, I was really impressed with both products. I purchased both from Amazon.
I always use Dicor on the roof.
2016 Bighorn 3760EL
2015 F350
me, DW and Mattie dog
dcason
New York
Posted: 08/22/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Okay I ordered some...thank you.
jplante4
Cape Cod
Posted: 08/22/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Shop where I work uses this exclusively for everything.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
garym114
Bluff Dale, Texas
Posted: 08/22/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Geocel Proflex, to help smooth use a spray bottle with soap and your finger.
Getting it wet is OK
