RV.Net Open Roads Forum: Technology Corner: Dish from DirecTV Conversion Coax Question
 > Dish from DirecTV Conversion Coax Question
chuckbear
Posted: 08/22/19 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
In the process of converting the Travlr, I see the LNB has 3 cables instead of one like the DirecTV. They are green, red and black. They connect to A,B, and C in the bottom of the turret. I thought I read somewhere that they need to be connected correctly to make everything work right. Can someone help with the connection sequence? Thanks. Chuck
2oldman
Ca
Posted: 08/22/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, I'll be the first to ask.. do you have an owner's manual?
chuckbear
Posted: 08/22/19 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
There is no owners manual and the installation instruction for the "conversion" do not really cover my question. I would appreciate a response from anyone that has done the DirecTV to Dish conversion on the Winegard Travlr. Chuck
Bill.Satellite
Full-timer
Posted: 08/22/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
If there is only 1 coax (really small coax) in the arm between the base and and the coax then you should have been sent 2 additional thin coax cables. You do need 3 coax from the LNB to the top of the base (1 for each satellite) and then 3 connections from the base of the antenna to the Dish splitter.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
RLS7201
Posted: 08/22/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe this will help. There is a PDF in this link that should help you.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
chuckbear
Posted: 08/22/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Bill, There are 3 coax from the LNB. As I said they are color coded black, green, and red. The ports are A, B, and C. My question again is what color needs to go to A? What color needs to go to B? What color needs to go to C? Richard, that post and diagrams do not answer my question. I really need some feedback from anyone that has done this as to how you made the connections. The connections from the base to the DPH42 switch is not an issue. I have that covered. Chuck
TechWriter
On The Road
Posted: 08/22/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
The three coax cables from the DISH Travler (A, B, and C) should be run inside your RV. Then they connect (in no particular order) to a DPH42 switch:
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
chuckbear
Posted: 08/23/19 05:02am Link  |  Quote  |  Print  |  Notify Moderator
TechWriter, Still not showing me the coax I ask about. They are coax FROM the LNB and not the coax into the RV. Chuck
TechWriter
On The Road
Posted: 08/23/19 09:21am Link  |  Quote  |  Print  |  Notify Moderator
See IRV2 thread.
chuckbear
Posted: 08/23/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I guess I am installing the Dish Pro Plus since that is what Winegard sent me and I have an older dish. Chuck
