RV.Net Open Roads Forum: Full-time RVing: Hooking up to a well
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Hooking up to a well
Hexmon
Ellsworth, ME
Posted: 08/23/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
We live in out TT full time off grid. Its been a bit of a challenge but very rewarding. We recently bought our own piece of property and it already has sceptic, well, and electricity.
The challenge I am facing where I need help on is how do I connect the well to the TT?
It had a pump in the well, a black hose coming out of the ground with a wire wrapped around it. I have been told I needed a pressure tank to make this work but not sure about the size i need and what it all entails. Any help would be appreciated as I have not been able to find anything about it online.
Also Hi, I'm new here so be gentle lol.
enblethen
Moses Lake, WA
Posted: 08/23/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
You would connect the same way as if you were in an RV park.
Now lets go with some concerns.
If you have a well setup that requires a pressure tank, get install before connecting.
If you have a variable speed submersible pump, you are better off. The pump will turn to provide water closer to what the rig's is require for the number of faucets.
Get a good quality pressure regulator. Connect it to the water spigot. When the pump with pressure tank runs it could have pressure switch setting too high for your RV.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
NMDriver2
New Mexico
Posted: 08/23/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Get the well tested first and then test the water quality. Ask the well tester what size pressure tank he recommends assuming the well is good. I do not know about your state but here in NM you must also transfer the ownership of the well to your name with the state engineer. Here the well ownership does not necessarily transfer with the land title.
Turret Class traveler
agesilaus
North Florida
Posted: 08/23/19 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
In Florida the county health dept does well water testing for free, so you may want to check on that before paying. Call them and see what sort of sample the want and since you are not in FL see if they do this. If not ask them to recommend a lab. Do not use Calgon or some other such testers. The big thing they will check besides basic chemistry is for coliform bacteria which will reveal if your well is too near a sewage source.
I was an environmental chemist for 32 years and I have no idea why you would ask them about plumbing issues, aka expansion tank size. That's a question for the well driller to answer. Or just look on Youtube
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
garym114
Bluff Dale, Texas
Posted: 08/23/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
For a permanent installation you should have a PVC pipe for the well pump discharge, get rid of the hose.
This pipe connects to a well pump tank. The pump is cycled as needed by a well pump pressure switch, switch is controlled by the pressure in the tank, typical 30 to 50 psi is all that is needed.
There may be variations depending on how deep the well is, shallow well, jet pump or submerged pump.
Of course all this needs tp be in and insulated pump house to keep from freezing.
Tanks have a diaphragm, air loaded on top and water below, come in all sizes. For just a TT a 15 gallon tank should work. Remember, when the pressure drops in the tank because of use the pump cycles on to maintain pressure
Tanks:
https://www.amazon.com/Amtrol-WX-203-Wel........=9027391&hvtargid=pla-309461322382&psc=1
could be as simple as this for a shallow well
https://www.homedepot.com/p/Superior-Pum........ank-System-With-24L-Tank-94525/302330531
* This post was last edited 08/23/19 02:03pm by garym114 *   View edit history
Johno02
Lexington, TN USA
Posted: 08/23/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Find someone in your area that drills or services wells and well pumps. They will be your best source of information about local requirements. Normally, a well is pumped into some type of holding tank, with necessary pressure switched to maintain a set pressure without having the pump run all the time. These are usually located in a weather proof structure somewhere close to the actual well. Direct connection to the well pump is usually not recommended, due to whatever pressure is available at the wellhead. So, best to find a local authority, and have the installation done properly.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
garyemunson
Reno, Nevada
Posted: 08/23/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I hope you have checked zoning to be sure you can legally live in a trailer on the lot. If you are surrounded by other trailers you are probably ok. If that lot had a well, septic, and power installed for a house, you might be out of luck.
Dutch_12078
Winters south, summers north
Posted: 08/23/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
The well cap may have some information stamped on it about the well depth and the driller's contact info.
Dutch
2001 GBM Landau 34' Class A
enblethen
Moses Lake, WA
Posted: 08/23/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
The well may already have a pump in it!
OP: what is your information about the well?
naturist
Lynchburg, VA
Posted: 08/23/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
You would need to know if the pump is wired for 240 volts or 120 volts. It could be either. If you can determine who installed it, they should be able to tell you. Ditto the previous owner.
The advice to hire somebody who knows what they are doing is good advice.
