RV.Net Open Roads Forum: Tech Issues: Charging cable????
 > Charging cable????
joelyn
Az
Posted: 08/23/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 12 volt U1 battery strapped down in a battery box mounted to my mobility lift to operate it. When I want to charge the battery I have to take the chain off and untie the strap (which is on pretty good) to open the box and charge the battery. and repeat to strap it on again..
Do they make some type of cable that I can bolt onto the neg and pos terminals and just have the other end hang out of the box. strap up the box and when I need to charge the battery I just have to connect the charger to the cables hanging out of the box.
Make things a lot eaiser.
THANKS AGAIN FOR ANY SUGGESTIONS..
enblethen
Moses Lake, WA
Posted: 08/23/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
2 conductor brake cable would be a good choice.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Neil Citro
IL
Posted: 08/23/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
They make battery chargers where the cables unhook and stay with the battery. I have one on my ATV, makes it easy to hook up when I park it for a while. This is just a random link, but I would think anything similar:
https://www.amazon.com/dp/B07VFFBRNP/ref=cm_sw_em_r_mt_dp_U_tglyDbEV82KFA
2017 Grand Design Reflection 28BH
2019 Ford F350 SD 6.7L
garym114
Bluff Dale, Texas
Posted: 08/23/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Something like this, for a trolling motor battery
https://www.homedepot.com/p/Attwood-Trol........ng-Motor-Quick-Connect-14367-6/308145257
time2roll
Posted: 08/23/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
A cable can be easily made with ring terminals on the battery and some push connects to match the charger.
675w Solar pictures back up
belairbrian
Alabama
Posted: 08/24/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I thingk garym114 is on the right track. If the box has room for it maybe one like this. I added one to our previous 5er to power a maceator pump
Attwood trolling motor connector
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison
2009 Chaparral 278DS
Reese 16K Slider Hitch, Prodigy 3 BC
USAF Retired
WAR EAGLE
Wherever I happen to park
Posted: 08/24/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
They make many.. There is the FLAT 2 Connector (Any Auto Store) LIke the flat 4 trailer connector but only two polarized pins.
I use a whole bunch of Anderson Power Poles (westmountainradio.com if I am not mistaken as well as hundres of other dealers my last pack was from gigaparts.com)
These are crimped onto 10Ga or smaller wire and let me move radios from ride to ride.. and so on They are Asexual and polarized an be configured as any number of contacts.
There are many other 2-connector options as well
Home is where I park it.
joelyn
Az
Posted: 08/24/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone again. I found one that I can use after all the suggestions. Didn't realize it was that simple??
As usual I came to the right place for the answers, thanks again.
down home
south
Posted: 08/25/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Take a clean sheet or paper and a photo of the battery box and the area and design an exterior lug mount and routing. Measure and then find parts store or truck service that will make you a couple of batter cables with crimped on water proof lugs, Might take a bit of a search for the idea items but Tow Truck Drivers and Off Roaders use to make battery cables that ends extended through the grill an inch or so to jump off others or be jumped off, or supply power to electrical items when they camped out. look on line for what is currently available for battery cable ends and rubber covers if you want and design a first class puppy.
