RV.Net Open Roads Forum: Seeking Towing Guidance - Looking to pull TT with Expedition
 > Seeking Towing Guidance - Looking to pull TT with Expedition
dmboiler
Central Indiana
Posted: 08/24/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
New to the forums. We've owned a Keystone Sprinter 311BHS in a semi-permanent campground for 6 years and are looking to sell it and buy a travel trailer that we can take around to various state & national parks.
We will be pulling the new trailer with a 2013 Ford Expedition. It has the heavy duty towing package and is rated at 9000 lbs. max trailer weight and 15,000 GCWR per Ford's 2013 towing guide.
I'm curious if there is any general guidance to how close to these limits we should get. We've been around to a couple local dealerships and I've gotten some mixed advice. We've been looking at trailers in the 5500-6700 UVW range (24-28 ft bunkhouses). At the top of that range we get within 500-800 lbs of the GCWR when we factor in fuel and the weight of the family in the truck. This seems to me to be really pushing it, but I don't know if I'm being overly cautious.
I obviously want to stay as safe as possible and also want to not be limited to where I can pull the trailer. At the same time, I don't want to miss out on some of the benefits that a larger trailer can provide. Any advice is greatly appreciated.
Thanks,
dmboiler
DutchmenSport
Indiana
Posted: 08/24/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
A friend / colleague at work has an Expedition of about the same vintage. He recently purchased a 30 foot Keystone Passport. I gave him my Equal-i-zer 4-point weight distribution hitch and all the paraphernalia I had from my previous travel trailer. His expedition was already equipped with the brake controller, all the wiring, and everything. He said, it tows just fine!
Every now and then, I'll see his Expedition in the parking lot and he'll have that hitch attached. It kind of brings back good memories of my Outback TT. I now have a fifth wheel.
Get a good weight distribution system, and you'll probably be OK.
Bishop, CA
Posted: 08/24/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Six thousand was my self imposed limit with a similar Tahoe. Remember the longer the TT the fewer the campsites.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
bikendan
Camano Island, Wash.
Posted: 08/24/19 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Those numbers you're quoting, are max amounts for a properly equipped Expy. NOT for every Expy.
So you need to post the driver's door yellow sticker payload capacity. It's on the Tires and Loading sticker. It'll say Occupants and cargo should not exceed xxxxlbs".
Another sticker will have axle capacities.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
theoldwizard1
SE MI
Posted: 08/24/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
My daughter's family has similar setup. They have been to Disney World from MI with no issues.
Stay below the recommended maximums (it is easy to exceed the vehicle cargo capacity with a large family) and you should be okay. Also drive a speed where you are comfortable. If that is 60 MPH on an interstate, do it ! It may mean one more hour of driving per day, but you will not be stressed out.
theoldwizard1
SE MI
Posted: 08/24/19 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
twodownzero
NM
Posted: 08/24/19 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
My advice is to look at your GVWR in the door jam and weigh your truck. The rear suspension is not really suitable for heavy trailering. The GCWR probably does not matter because you will overload your truck before you get near it.
dmboiler
Central Indiana
Posted: 08/25/19 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for the information and advice. Below is some data from the stickers on the driver's side door frame:
GVWR: 7500 LB
Front GAWR: 3550 LB
Rear GAWR: 4250 LB
The combined weight of occupants and cargo should never exceed: 1508 LB
troubledwaters
Potomac
Posted: 08/26/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Best to have the unbiased informative facts rather then Internet speculations; so you can make informed decisions. Clicky
twodownzero
NM
Posted: 08/27/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
GVWR: 7500 LB
Front GAWR: 3550 LB
Rear GAWR: 4250 LB
Next you need to weigh your truck with all the occupants and things inside of it you'd have in it when you tow the trailer. I think you're going to find that you only have about half of that 1500 pound payload remaining, which is going to restrict you to a trailer in the 5-6000 pound range max, and even that is going to require careful loading. You need a 25 foot lightweight TT at most. 30+ feet isn't happening unless you buy more truck.
This is the unfortunate consequence of trying to make SUVs more car like, even full size SUVs.
