RV.Net Open Roads Forum: Tech Issues: Odd tire wear
 > Odd tire wear
N-Trouble
NorCal
Posted: 08/25/19 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
What would cause this odd wear on only the outer tread blocks? Inner tread blocks are smooth/round. These are the only two tires on the trailer that show this type of wear.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
12th Man Fan
Flower Mound , Texas
Posted: 08/25/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Low air pressure!
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Busdriver
Shepherdsville Ky 40165
Posted: 08/25/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe out of balance
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
time2roll
Posted: 08/25/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I read mismatched pressure or diameter.
675w Solar pictures back up
N-Trouble
NorCal
Posted: 08/25/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
They are the same tire brand/size.
DutchmenSport
Indiana
Posted: 08/25/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Out of balance AND under inflated. It's a combination of both:
Here.
It is a combination of under inflation and cupping.
Cupping is caused by being out of balance (or) a result of bad shocks, bad struts. Read here. This explains a lot more.
2oldman
New Mexico
Posted: 08/25/19 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Carlisle tires.
97chevor
US
Posted: 08/25/19 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of trailer is this? Semi? Tandam axle? duals? Spread? Looks like your dragging the tires through right turns.
jjrbus
FT Myers FL
Posted: 08/26/19 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Took RV for tires and had balanced. Did not drive RV for long time and ended up at another shop to have checked due to vibration. Guy comes back in office with a huge handful of wheel weights and asks who balanced my tires as they have absolutely no idea what they are doing! I know they were my weights as I had painted rims and they had paint on them, all of them.
Use this shop exclusively now for alignments and such, RV will not fit in bay so they align it in the parking lot. Also do tire shaving for out of round
tires and they are reasonably priced. Alignment is $59
West Coast Alignment, Ft Myers FL.
eHoefler
ozark mountains
Posted: 08/26/19 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Suspension bushing need replaced, axle is walking around from worn out bushings
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
 > Odd tire wear
