RV.Net Open Roads Forum: Travel Trailers: question about battery
 > question about battery
Npdchief07
Hamilton, Oh
Posted: 08/26/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Can someone explain to me what the battery actually does on an rv? I just got a new 2020 Transcend. It has a battery disconnect switch. When I park in our drive, I turn the disconnect to on. It has been parked for a week and battery is dead (the slide won't go out, lights don't come on etc.). I have plugged it back in to an outlet and it appears to be charging again.
What exactly does that battery power? If it has a disconnect switch in the rv, should I still disconnect the cables?
I don't understand electrical. I don't know a volt from an amp.
mgirardo
Brunswick, GA
Posted: 08/26/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The battery disconnect switch disconnects the battery from the TT. When the battery has been disconnected and you aren't plugged into shore power, pretty much nothing will work in the RV. The lights use 12v battery power as do any fans. The furnace and fridge both use 12v as well as any USB/12v power outlets. Most propane/CO detectors use 12v as well. The smoke detector most likely uses a 9v battery.
If the battery is in the On position, it is not disconnected and the battery will drain pretty quickly.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Npdchief07
Hamilton, Oh
Posted: 08/26/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
So when not in use I should have the battery disconnect turned to off?
Jebby14
Windsor Ontario
Posted: 08/26/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
yes though if you are close enough to home to be plugged in why not leave the unit plugged in so its ready to go and fully charged all the time. during the camping season when my unit it home its plugged in. battery starts every trip full and fridge is cold so all we need to do is toss the food in. also allows me to run the air if im going to be working in the camper or cleaning it I can cool it down.
cougar28
Lowell,AR USA
Posted: 08/26/19 08:36am Link  |  Quote  |  Print  |  Notify Moderator
You household electric 120vac runs a converter (battery charger) to charge the battery. The battery is the reserve power to run 12vdc intermittent items such as your slides - power awning- power jacks and small 12vdc drain items such as lights. The a/c and water heater (if heating on electricity) requires you to be plugged in on 120vac. The battery disconnect is used to turn off the battery to everything in the rv during storage. If the rv sits for a period of time with the batteries not disconnected and not plug into 120vac the rv still has a small drain on the battery and will run it down over a period of time. The converter is not designed to run the 12 vdc power alone it needs the battery reserve so the larger 12v drain items is not pulling power solely of the converter.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
2oldman
New Mexico
Posted: 08/26/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Everything 12v: lights, jacks, slides, refer control board, furnace control.
Volt = pressure
Amp = volume
opnspaces
San Diego Ca
Posted: 08/26/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
The battery powers basically everything electric in the trailer except for:
  • Air conditioner
  • Microwave
  • All the 120v (household style) outlets)
  • The converter/charger which charges the battery
All of those items above are powered by plugging your shore power cord into an outlet. Everything else is powered by the battery.
Even if you turn off everything in the trailer there are parasitic loads, things like the propane alarm and memory settings on entertainment system that are always on and draining power from the battery. These parasitic loads can drain a fully charged battery in 1-2 weeks.
If you are able to plug into a 120v outlet at home the converter/charger in your trailer will charge the battery back up.
Having the battery drain below half it's capacity is damaging to the battery. If you cannot plug in to a power source you should use the disconnect switch.
Except if you are using the refrigerator it needs to use the battery or be plugged in, even when it is running on propane.
So basically if you are parked in your driveway you might as well plug it in and keep the battery charged. But you should also check the water level in the battery at least once a month until you get an idea how fast the water is evaporating. Letting the water level drop and exposing the plates is also damaging to the battery.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 08/26/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Yes. Unless you plug in then it may as well be on to get the charge topped up.
The 12 Volt Side of Life
675w Solar pictures back up
camperdave
northern, California
Posted: 08/26/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Even with the disconnect switch on the off position, you will still have a small load. On my motorhome, the propane detector is always powered, even when the 'disconnect' switch is off. A few other little things too, like the electric steps and I don't remember what else offhand...
For long term storage (anything more than 2 weeks), I pull the cable between my batteries (dual 6 volters).
And I'd highly recommend the link time2roll posted. Even if you are not mechanically/electrically inclined, understanding the electrical ins and outs of your RV will be very worthwhile. That page is a classic, written a long time ago and still stands the test of time.
2004 Fleetwood Tioga 29v
2oldman
New Mexico
Posted: 08/26/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
They should call it a battery connect. That way it makes more sense to be "off."
