RV.Net Open Roads Forum: Tech Issues: Atwood water heater electric switch
 > Atwood water heater electric switch
ceasare
staten island
Posted: 08/26/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
I thought our water heater wasn’t working on electric, Now I find out that it was. light in the switch that wasn’t working. Ok pick up a new switch and the water heater is still working but the light in the switch is still not. Any other ideas? As usual thanks a million.
Learjet
Louisiana
Posted: 08/26/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
dumb question...but you got the same lighted switch? 12 volt or 120 volt pilot light?
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Bobbo
Wherever I park
Posted: 08/26/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Was the light ever working? You need 3 connections to the lighted switch. You have the hot wire to the switch, you have the wire from the switch to the relay that turns on the 120v heating element, and you have the ground wire that is only required so the switch will light up.
If the heating element is working, then wires 1 and 2 are working. The only other possibility is the ground wire is not grounding.
(Once the switch lights up, if it is lit up ALL THE TIME, you have wires 1 and 2 reversed.)
Bobbo and Lin
DFord
Near St Louis, MO
Posted: 08/26/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
The original switch probably had an incandescent lamp. They make that switch with an LED lamp but you might have to look closely on the package to tell them apart. The LED isn't as bright but doesn't have to be - I can tell the difference between on and off. It will last much longer too!
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Wherever I happen to park
Posted: 08/27/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
One you may have mis-wired the light
Two.. I installed an "Indicator light" (led) next to the switch way easier than a new switch.
Home is where I park it.
