RV.Net Open Roads Forum: Fifth-Wheels: broken springs
 > broken springs
voodoo101
arizona
Posted: 08/27/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I discovered a broken spring on my fiver about 5 years ago. Considered it an anomaly and replaced it. This summer I discovered another spring broken while on the road in Utah. Stopped at a Flying J in Scipio to get it replaced and found two were broken, one on each side. The second probably happened on the crappy section of IH-15 south out of Salt Lake while I was looking for a repair shop.
Anyway, getting to the point I had all 4 replaced with heavier 5 leaf springs vs 4 leaf that came on it. Sunnybrook made excellent trailers in that time frame but like all manufacturers they used only the minimum required. The OEM tires were D rated (just barely enough) and I upgraded to E. I am sure the springs were adequate, but probably just adequate. Something to consider if one is having suspension work done. FWIW
Cummins12V98
on the road
Posted: 08/27/19 11:02am Link  |  Quote  |  Print  |  Notify Moderator
If a person has time to order what they want there are US Made springs available.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
time2roll
Posted: 08/27/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
If one goes I would always recommend replacing the full set.
Mine were sagging after a decade and were replaced with a higher weight rating. Has never ridden better.
675w Solar pictures back up
ford truck guy
Pennsylvania
Posted: 08/27/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
I agree.... if I had 1 that went, ALL would be gone at the same time!
Not worried about that now, the Morryde IS is an BEAST !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
RoyF
Fayetteville Arkansas
Posted: 08/27/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with replacing all four. My original springs were rated 3,000 lbs; weignt on each wheel about 2,500 lbs. After breaking one spring, I replaced all with 4,000 lb springs. That was nine years ago and there have been no spring problem since the replacement.
Lynnmor
Red Lion
I had EMCO brand, made in USA springs on a new trailer. They really looked nice with well formed eyes in each end. One had the locator off center, one sagged and one broke all within the first three years. I replaced with springs from Redneck Trailer Supply, they appeared more crudely made, but they have been working ever since. I believe it is all about the steel quality and heat treating and there is no way to tell what you are buying.
buc1980
houston tx
Posted: 08/28/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Get ready of the worry install Morryde IS.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
B.O. Plenty
Minnesota
Posted: 08/28/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced all four springs on my Cedar Creek. Not that big of a job. Replaced all the hardware, u-bolts etc. to make it easier to work with. Did one spring at a time only taking off one wheel at a time. Not a bad job and it took about four hours to complete.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
garyp4951
TN
Posted: 08/28/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
SD Truck springs sells US made leaf springs.
larry barnhart
wenatchee. wa usa
Posted: 08/28/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
. The shiney tab that wraps around be the springs has a code number that tells what it is for buying a new spring. Just info in case some might not know. Chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
 > broken springs
