RV.Net Open Roads Forum: Travel Trailers: Don’t know anything
 > Don’t know anything
Dougcox20
Southaven, MS
Posted: 08/27/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
I’m gonna buy a travel trailer and something to tow it with. Should I buy new or used? What brands are the best? I plan on doing full time. Any advice would be appreciated.
Thanks
Npdchief07
Hamilton, Oh
Posted: 08/27/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Could use a little more information... Is money an object? How big a travel trailer?
Beverley&Ken
Tottenham,Ontario
Posted: 08/27/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yes a little more info, 'full time, lots of travelling or stationary most of the time. Single or family in the RV, needs work station or something else.
My suggestion would be to start with a used unit, new unit kinks should be worked out, How much do you want to spend? If used and you decide that you don't like the life style, not as much money invested.
Get or decide on a particular RV first, then look for a tow vehicle. Go at least size bigger on the tow vehicle than you would need for that trailer. i.e. if a 150/1500 is adequate to tow the trailer, look at 250/2500 or even 350/3500 series that will make for a more relaxed tow, and may accommodate your next trailer when you decide your original choice is TOO small.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
TenOC
On the road -- Full time
Posted: 08/27/19 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
1. Used since first year deprecation on TT and TV are high.
2. Look for a floor plan with lots of storage -- not a brand name.
3. Get a Hensley Arrow or ProPride hitch.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
West & above Bishop, California
Posted: 08/27/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
1. Buy or select the TT first...then match a TV to it.
2. Think TV "payload" first and then TV max tow weight.
time2roll
Posted: 08/27/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Get down to an RV show. Walk through some trailers. Do not buy anything. Give us your thoughts. We can then estimate what vehicle can pull what you are thinking about.
Unless money is easy I always recommend starting with a preowned RV. Probably same for the truck.
675w Solar pictures back up
Dougcox20
Southaven, MS
Posted: 08/27/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I could swing the money, but the money supply is far from endless, so I would like to make smart money decisions. I guess space for four. Just me for sure, but I could see others joining at some point. Full-time. I can see 2-4 weeks in one location before moving on. I have read people writing about some brands with poor manufacturing, leaks and busted floors?
wanderingaimlessly
SOBOVA
Posted: 08/27/19 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
The questions for the OP start with trailer size, which also then dictates Truck size, and drivetrain.
One person alone even with some dry camping can get by with a 25' box and a half ton truck pretty easily. ie; a F-150 with a tow package and either a 5.0 or 3.5 Ecoboost.
Mid lever trailers for example could be 2520 Passport models or 223rbs Coachmen.
Or you could look for heavier trailers, with longer living spaces, and go to 2500-3500 trucks with or without diesel powertrains.
It's all up to your taste and wallet depth.
1492
Arlington, VA
Posted: 08/28/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
Jebby14
Windsor Ontario
Posted: 08/29/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
full time is a different animal. how much "stuff" will be living with you. I camp light but for an extended stay would be very heavy. Also how mechanical are you? maintenance will be constant. the problems you mention are more often than not from lack of upkeep not from a brand specific problem.
