RV.Net Open Roads Forum: Fifth-Wheels: Parking Light with Jumper
 > Parking Light with Jumper
Bnadon
Barraute
Posted: 08/27/19 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all, I Bought a Puma 2012 259 RBSS, All working well But The thing Is when i try to get my Parking light on With a 10a fuse in the 7way connector My parking light dont work, Then i tough its was a groud Problem , so i try to plug my 7way in my truck without being coupled and Its work fine, all my light open .. so now what can be the problem ?
Sorry for my bad english [emoticon]
Learjet
Louisiana
Posted: 08/27/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
The trailer charge circuit is not hooked to battery or blown fuse in charge circuit line on trailer.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
enblethen
Moses Lake, WA
Posted: 08/27/19 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
The center pin of the trailer connector should be for back up lights. the purple wire in the trailer cord should power your docking lights.
Need to query what you are calling parking light?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ScottG
Bothell Wa.
Posted: 08/27/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Since they worked when plugged into your truck, I'd say there was some problem with the jumper you made.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Goostoff
Wisconsin
Posted: 08/27/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
you sure you are jumping the correct 2 terminals? Red and Brown on this diagram should be jumped
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
* This post was last edited 08/28/19 09:17am by an administrator/moderator *   View edit history
1993 Chevy C3500
2005 Cedar Creek 34RLTS
opnspaces
San Diego Ca
Posted: 08/28/19 01:57am Link  |  Quote  |  Print  |  Notify Moderator
Look at the diagram above. The red wire on your trailer is not passing electricity from your trailer battery. Or the negative wire is not letting the electricity back into the battery.
  1. If you have a disconnect switch make sure it is allowing power through the switch. You can check by turning on an interior light
  2. The trailer battery is dead. Verify by turning on an interior light
  3. The trailer battery negative wire is not hooked to a good clean bare spot on the trailer frame
  4. Less likely, your truck and trailer wiring are not standard and you are just using the wrong terminals
Do you have a multimeter or a 12 volt test light?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
philh
Belleville MI
Posted: 08/28/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Why are you looking to power the running lights on the trailer?
enblethen
Moses Lake, WA
Posted: 08/28/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
I am still waiting for somewhat of the same answer, Philh.
He started asking about "Parking lights". Parking light term hasn't been used in years!
Other posters read it as tail lights and clearance lights from their posts.
Maybe he is one of those RVs that likes to llight up the campground!
Goostoff
Wisconsin
Posted: 08/28/19 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
Some people think it looks cool. Its not for me but if someone else wants to do it thats fine by me unless the rear of their trailer is 10 feet from my campfire or they leave them on all night. I would much rather see a red glow than these people that leave their scare lights on all night on both sides of the trailer lighting up the whole campground
opnspaces
San Diego Ca
Posted: 08/29/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Parking lights are the same as tail and running lights which are the same as side markers and taillights. We can each call them something different, but they are the same.Ultimately the OP wants his trailer to look like the tow vehicle headlights are on and he is not stepping on the brakes. So his markers on the top are illuminated as well as the license plate light and taillights (not brake lights
Is he "One of those RV's that lights to light up the campground!" Well he is apparently a camper who likes to turn on his (parking, running, tail, side marker) lights while he is camping. In over 20 years camping I think I've only ever seen one camper disconnected from the tow vehicle with the running lights on.
