Mickeyfan0805
SE Wisconsin
I'm nowhere near being a gearhead, and I can't seem to wrap my mind around how the Ecoboost outperforms the V8 in towing. I understand the fuel economy issue, but how is it that the V6 can actually have a higher tow rating than the V8? Can anyone explain in layman's terms?
TurnThePage
North ID
If you forget about descriptive terms like v6 and v8 and just look at the specs, it's pretty obvious. The Ecoboost builds twist early in the RPMs and applies it continuously. The v8 has to wind up before it achieves similar power. The v8 has a little more horse power, but it's only available at wide open throttle at very high RPMs. All the rest of the time the Ecoboost will be the more powerful engine.
2015 Ram 1500
2004 Pioneer 18T6
ShinerBock
SATX
Because the 3.5L Ecoboost makes more horsepower and torque than the 5.0L between 1,700 and 5,000 rpm especially between 2,000 to 3,000 rpm where it makes up to 75 hp and 150 lb-ft more. This low end power makes for more usable power in more gears and speeds. Similar to why a turbo diesel is a better tow engine than an N/A gas engine.
The 5.0L starts making more horsepower around 5,500 rpm which is good for the drag strip, but not for towing.
fx2tom
CA
Mickeyfan0805 wrote: I'm nowhere near being a gearhead, and I can't seem to wrap my mind around how the Ecoboost outperforms the V8 in towing. I understand the fuel economy issue, but how is it that the V6 can actually have a higher tow rating than the V8? Can anyone explain in layman's terms?
Overly simplified - turbochargers
Mickeyfan0805
SE Wisconsin
Exactly the type of siumplified answers I was looking for. Thank you!
parker.rowe
Delaware
Part throttle with a turbo is also an important difference as to why it feels like they tow so well too.
Turbo's are load dependent. Let's see if I can explain simply....
You a cruising at 1/4 throttle.
You hit a hill...engine is working harder (more load).
Turbo boost increase, power increases, you go up the hill without having to push the throttle more.
This doesn't address the tow rating increase, and obviously there are limits to this, but it does explain why people like the way towing with a turbocharged engine "feels".
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10 Gears
1977 Kawasaki KZ1000
twodownzero
NM
Two words: volumetric efficiency.
Under load, it moves more air, burns more fuel, and makes more power.
mich800
Pontiac, MI
Unfortunately the V8 vs V6 and straight vs V preconceptions are hard to break. This thread could probably be merged with the "what defines a 3/4 truck". It is about the performance of that component or assembly not what label you put on it.
dockmasterdave
florida
Because a 3.5 litre ecoboost, with the turbos open, displaces @ 6.0 litres of fuel and air.
6.0 litres beats 5.0 litres. Plus it makes over 80% of it's power from just above 1500 rpm, the 5.0 v8 probably doesn't make max power till 4000 rpm. Drive one and you'll understand.
2014 F 150 ecoboost
2010 F 150 4.6L
2007 ranger
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
RoyJ
Vancouver, BC
Very simple answer - because the EB makes more power.
At a given speed, power determines how much thrust you have.
