RV.Net Open Roads Forum: Tow Vehicles: Ecoboost vs. V8 - Can you explain?
Search only in Tow Vehicles
 > Ecoboost vs. V8 - Can you explain?
Page of 8
ShinerBock
SATX
Posted: 09/03/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
ShinerBock wrote:
JRscooby wrote:
Where is it written that gas engines must be V whatever? What would happen if they put modern fuel and spark control, and a turbo on a 5 L I 6?
They probably don't do it because of the cost associated with re-engineering a whole new motor/supporting systems and completely re-tooling the factories. It is much easier and more cost effect to re-scale and take away cylinders for various displacement sizes of a certain block configuration versus having two block configurations.
Cost associated with re-engineering a whole new motor/supporting systems and completely re-tooling the factories? IMHO, they did that.
Had a engine that was pretty cheap to run, and real dependable back when using points and carb. Instead of putting Fuel Injection on that when needed to clean the exhaust everything had to go V. Ford put throttle body on the 302 V8, and made big improvement in power and economy. Why not the 300 inch 6? If they had, then would not take much to add the turbo
It is not just about re-engineering an engine. You have to re-engineer everything that is attached to it as well like accersory drives, engine mounts and so on. Inline engines are also longer so you have re-engineer the cooling system too.
Then there is the re-tooling of the factories that are based on Ford's modular engine designs and other V engines. If you have ever been in an engine factory with all sorts of specialized equipment, tools, and jigs just for one engine configuration, then you know how much of an undertaking it would be to change all of them.
Not saying it can't be done, and would in fact love to see an inline 6 Ecoboost engine. I am just saying that the reason why they probably didn't go that route is the added cost versus just re-utilizing what they already have.
* This post was edited 09/03/19 02:29pm by ShinerBock *
Posted: 09/03/19 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
liberty02, cmon bud. I get it you like the Ecoboost. So do I, so does he, so does everyone....well maybe almost everyone.
But think about it. If it was really just that easy and lobbed up like a grapefruit to hit, do you not think that someone would have made a big forced induction gas truck motor by now?
If anyone could do it, it would be Ford because you can get a 48 gal tank in them. And you'd need it. It would shame a whole bar full of sailors with it's drinking problem! Add 50% more power across the board to set it firmly above big new NA gassers, but still less torque than the diesels but way more hp and 4mpg pulling that big 5th wheel up a mountain or across the great plains.
He!!, my buddy could get single digit fuel mileage with his blown TRD Tacoma in the mountains pulling an open sled trailer. But it was very peppy.
bikendan
Camano Island, Wash.
Posted: 09/03/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
Wouldn’t they simply lose that market share because spark engines are gutless compared to diesels so buyers will look elsewhere?
Another person that hasn't kept up with modern gas engine technology.[emoticon]
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
rjstractor
Maple Valley, WA
Posted: 09/03/19 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
They added fuel injection to the 300 as well in 1987 and it was the standard F150 engine until 1996 when the truck was completely redesigned. Even with EFI the 300 had only 145 hp.
parker.rowe
Delaware
Posted: 09/04/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
And physically was a monster. They would have been better off to design a new straight six then continue with the 300. It didn't even have a crossflow head.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
4x4ord
Alberta
Posted: 09/04/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
A major problem with putting a large displacement boosted gasoline engine in a truck designed for towing is that you'd never keep it cool. A 6.7 EcoBoost could easily make over 700 hp. A 700 hp towing truck would require a radiator larger than the one behind the grill of a Peterbilt.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
JRscooby
Indepmo
Posted: 09/04/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Back in the early '80s I had a couple of trucks from the late '60s. Both 2-stroke diesels, same rears, same transmissions, doing the same work. The I 6 was more power full and used less fuel than the V 6. Put new bearings, rebuilt head, new pistons and liners in the V 6. Cut oil consumption, but still could not work with the I 6. IMHO, inline is a better design...
srt20
Wisconsin
Posted: 09/04/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Inline maybe a better design, but they just dont fit in vehicles well anymore. Curved down hoods, shorter front ends, etc. The V block engines barely fit now. Look under the hood of a V8 diesel with turbos. Its shoved way under the cowl, and all the way to the radiator support. Then add 2 more cylinders to that length...
BTW I have a 3.5L Ecoboost. And either I have a bad one or there's alot of people that fib about their mpg. I got 7.9mpg towing a 30ft enclosed all aluminum 7.5ft wide trailer that weighed about 5000lbs loaded. And I havent seen 20mpg on the EVIC (which always reads high) in a LONG time.
Turbocharged gas engines need fuel.
Posted: 09/04/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
"BTW I have a 3.5L Ecoboost. And either I have a bad one or there's alot of people that fib about their mpg."
Well theres that. I maintain there's 3 things most men fib about. The size of the fish they caught, the size of their ____ and the fuel mileage of their truck. The internet is the king of outlandish fuel mileage claims (and a few people who literally drive so slow and miserly that they get passed by a stiff breeze).
APT
SE Michigan
Posted: 09/04/19 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Area under the torque curve is what most drivers notice. The green line shows how much torque is available under about 4500rpm than any other compared engine.
2017 Subaru Outback 3.6R
Page of 8
