RV.Net Open Roads Forum: Tech Issues: Bus Bars - 150A rated ok?
 > Bus Bars - 150A rated ok?
Page of 5
phemens
Montreal, Canada
Posted: 08/28/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Have 500AH battery (LIFePO4) and a 3000 watt Samlex inverter. Wiring is all going through bus bars. I made an order to get new ones, received Blue Seas 4 post rated at 150 amps. I thought I had ordered rated at 250 amp. Question is, do I really need to go to 250 amp (return and re-order) - what's my risk? Real world high draw use is occasional microwave, coffee maker, etc.
Other question is, I originally had 4x100 AH batteries all wired with 00 gauge welding wire. To add the new 5th one (bought within a few months of the others), I have some spare 0000 wire to make the cable (all wiring from batteries to bus bar is same length), ok to use or do I really need to find some 00 to make everything uniform?
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
BFL13
Victoria, BC
Posted: 08/28/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Remember that business with the fuses, where the total of all the various branch ampacities to the bus bar has to be equaled by the ampacity of the single main fat wire from the bus bar.
So obviously the bus bar itself has to have that total ampacity too.
Can't say about the fifth battery wiring. Lost track of that.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
2oldman
Ca
Posted: 08/28/19 09:38am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the voltage. Some mfrs recommend paralleling only 4 max. Is that your case?
Assuming 12v, only the inverter connections need to be 4/0.
pianotuna
Regina, SK, Canada
Posted: 08/28/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
My 3000 watt inverter tops out at over 270 amps. Return and reorder.
Regards, Don
phemens
Montreal, Canada
Posted: 08/28/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I'm ok for the 5 in parallel, yes, mfg confirmed.
I know only the inverter needs the 4/0, which it does. To clarify, my question is: in real-world situation, is there any significant impact in having one battery wired to the bus with 4/0 where the other 4 are all 2/0 (all wire lengths being equal, only variance is gauge)
Ok, I will bite the bullet on the higher amperage bus bars
2oldman
Ca
Posted: 08/28/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Now I remember.. you're wiring each battery separately to the busbar. Each battery contributes 1/5 of the required amps, in theory, so I wouldn't worry about the 4/0 thing..other than the hassle of working with it.
phemens
Montreal, Canada
Posted: 08/28/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Yes - all batteries separate to bus.
If I can scrounge up the 2/0 I will, but I know I have some lengths of 4/0 readily available, and all the lugs, so if I can avoid buying I will.
GordonThree
Northern Michigan
Posted: 08/28/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
X2, don't rush and settle for a weak link
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/28/19 10:41am Link  |  Quote  |  Print  |  Notify Moderator
DLO
Diesel locomotive cable
https://skycraftsurplus.com/20-awg-dlo-2-kv-black-blk-20-awg-rp5878.html
It is the best quality cable I have ever used. Notice the multi sheathing. The outermost layer may be a much as 10-times tougher to cut or abrade than the stuff West Marine or Genuine Dealz, sell.
The inner layers are water and gas-proof. Acid proof, chemical proof.
I use RED shrink tubing to ID positive cables. DLO cable is black.
The tin plating is three times as thick as what's on, Anchor Wire
Rope stranding for best ampacity.
And Skycraft sells it at 50% off.
But 30' is the minimum purchase of 2/0 size
3/0 rated terminals highly recommended because 2/0 won't fit. Way too tight.
Far and away better cable than simple welding cable which has sheathing that has no cut or abrasion resistance.
Skycraft is in FL. The wire ships from a west coast warehouse.
phemens
Montreal, Canada
Posted: 08/28/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Ordered 2x Blue Seas 250A 4 post (for distribution), and 2x Blue Seas 250A 6 post for batteries. No more weak links (putting aside the human factor [emoticon]
Page of 5
