RV.Net Open Roads Forum: Tech Issues: Bus Bars - 150A rated ok?
 > Bus Bars - 150A rated ok?
Page of 5
phemens
Montreal, Canada
Posted: 08/28/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Interesting product. Unfortunately for us poor canucks the shipping cost exceeds the product cost....
MEXICOWANDERER wrote:
DLO
Diesel locomotive cable
https://skycraftsurplus.com/20-awg-dlo-2-kv-black-blk-20-awg-rp5878.html
It is the best quality cable I have ever used. Notice the multi sheathing. The outermost layer may be a much as 10-times tougher to cut or abrade than the stuff West Marine or Genuine Dealz, sell.
The inner layers are water and gas-proof. Acid proof, chemical proof.
I use RED shrink tubing to ID positive cables. DLO cable is black.
The tin plating is three times as thick as what's on, Anchor Wire
Rope stranding for best ampacity.
And Skycraft sells it at 50% off.
But 30' is the minimum purchase of 2/0 size
3/0 rated terminals highly recommended because 2/0 won't fit. Way too tight.
Far and away better cable than simple welding cable which has sheathing that has no cut or abrasion resistance.
Skycraft is in FL. The wire ships from a west coast warehouse.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
Morro Bay, CA
Posted: 08/28/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Very interesting, Mex.
2oldman
Ca
Posted: 08/28/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Wish I could talk you into higher voltage so you wouldn't have to mess with this fat cable and long wire runs. But with 5 batteries that won't work so well.
phemens
Montreal, Canada
Posted: 08/28/19 11:41am Link  |  Quote  |  Print  |  Notify Moderator
well, the fat cables are already sunk cost, and with Lithium the voltage isn't really a factor. I don't have any long wire runs, my longest cable is the one from the bus to the inverter and that's 2 feet (vs. 1.5 feet for each of the batteries). No business case there for me [emoticon]
2oldman
Ca
Posted: 08/28/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
No, but the amperage is.
phemens
Montreal, Canada
Posted: 08/28/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
For amperage I can draw max 100 amps per battery, in parallel that gives me 500 amps theoretical. Max draw from the inverter is about 250 amps (excluding very short duration peak 6000 watts but I'll never reach that with any equipment I'm currently carrying).
Chris Bryant
Arden, North Carolina
Posted: 08/28/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
If I am understanding correctly, the battery bank with the 4/0 cable will discharge and recharge faster, thus be stressed more.
I’m sure the difference can be calculated.
-- Chris Bryant
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 08/28/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hyper amperage may affect ampacity but batteries automatically lose that as their load is increased.
With a 200 amp inverter draw from 4 three cell gc220's and the inverter 10 feet distant from the batteries an increase from 2/0 to 4/0 cabling may allow for perhaps a 10 amp increase. Irrelevant. Some of the limiting factors are design limits of battery values with regard to CCA
My system is 24 cells 28 volts and 350 MCM cable. Utter maximum of 720 amperes charge rate with the generator itself as the limiter >17 Kw. There is almost zero voltage drop. Similarly under design limit extraction by the 4024 inverter voltage drop throughout the system is <.9 volts.
2oldman
Ca
Posted: 08/28/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I'm sure that would depend on the charge amperage, which is not likely to be hundreds of amps. And it's just one battery, not a bank.
* This post was edited 08/28/19 01:12pm by 2oldman *
MEXICOWANDERER
Posted: 08/28/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Too little emphasis is given to the integrity of the lug to buss and the lug to the battery interface. With hyper amperage, these junctions are given insufficient importance.
My buss are 30" x 6" by 3/4". Gold plated by AFSCO Oakland CA. Half inch by 16 TPI 316 stainless steel hardware. f I remember correctly, both buss bars cost in excess of 400 dollars just for the gold.
I traded a redesigned 20SI Delco alternator for the plating job. It charges at 22 amps at dead idle when nothing else would. Stainless serrated 316 nuts are used.
Volt drop total is an aggregate value.
Page of 5
