RV.Net Open Roads Forum: Tech Issues: Bus Bars - 150A rated ok?
 > Bus Bars - 150A rated ok?
Page of 5
GordonThree
Northern Michigan
Posted: 08/28/19 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Why would a very low voltage DC application need cable as heavily insulated as that locomotive cable?
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
pianotuna
Regina, SK, Canada
Posted: 08/28/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Wish I could talk you into higher voltage so you wouldn't have to mess with this fat cable and long wire runs. But with 5 batteries that won't work so well.
X2
Regards, Don
2oldman
Ca
Posted: 08/28/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
It doesn't. It appears that cable is designed for harsh duty like chemical spills and proximity to sharp things.
I was looking for busbars (distribution blocks) with screw terminals which makes connections very easy. When I was in the 4/0 business I used screw terminal blade connectors. Very nice. Never came loose.
time2roll
Posted: 08/28/19 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
phemens wrote:
Ordered 2x Blue Seas 250A 4 post (for distribution), and 2x Blue Seas 250A 6 post for batteries. No more weak links (putting aside the human factor [emoticon]
Probably fine. I was about to recommend the 600 amp.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 08/28/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Chris,
Yes, you are correct.
There are built in battery management systems which may (or may not) mitigate the differences.
Chris Bryant wrote:
If I am understanding correctly, the battery bank with the 4/0 cable will discharge and recharge faster, thus be stressed more.
I’m sure the difference can be calculated.
phemens
Montreal, Canada
Posted: 08/28/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
the 600 amp bars seemed a little bit overkill - 4 of them would pay for another battery! So far I've not seen a draw over 230 amps on the inverter, so I think 250 should be fine.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
2oldman
Ca
Posted: 08/28/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
(re: 4/0 cable vs 2/0) Yes, you are correct.
I think I have to question your answer piano.
Assuming the charge rate is say, 100amps, that's 20 amp/battery. Are you saying the slightly different resistance of the 4/0 vs 2/0 is going to make any significant difference?
As for discharge, yes, at hundreds of amps there could be a bit more difference.
Wherever I happen to park
Posted: 08/28/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Let me put it this way. 3,000 watt inverter draws close to 300 amps perhaps a tad more at startup but at full load it will be sucking roughly 300 amps (Divide by 10.. note it is not accurate at thousands of watts but it's close enough for estimating load) My 2000 watt can hit 220 amps.
Home is where I park it.
pianotuna
Regina, SK, Canada
Posted: 08/28/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman,
If there is a difference in resistance--then it affects how the batteries charge. LI? Well I don't know. But flooded or agm--for sure it makes a small difference.
time2roll
Posted: 08/28/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Seems odd to have 4 bus bars.
Page of 5
