RV.Net Open Roads Forum: Tech Issues: New TV reception
 > New TV reception
crawford
Dandridge Tenn.
Posted: 08/28/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
The new Digital signal some days it is good then some days it's poor. Now mine you nothing have change moved nothing is this the nature of the beast. I put up many different antenna's all perform about the same. Yes even Newest TV also
Change from a c class to a A class Georgetown 07 triple slide
midnightsadie
ohio
Posted: 08/28/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
with a normal rv set up yes its not very good. to get great set up you need a dish.
shastagary
minnesota
Posted: 08/28/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
tv signals just like radio signals are affected by weather atmospheric conditions and signal blockages like hills buildings and trees.
wet leaves on trees block evan more signal. the best way to get a better signal is to raise your antenna height above all obstructions but your distance from the transmitters is the biggest factor in getting the best reception and its always better at night.
CA Traveler
The Western States
Posted: 08/28/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
With the advent of HD most of the channels are now higher frequency (UHF) and much more line of sight. Anything in the path can cause problems including say a tree swaying in the breeze.
In my experience straight line of sight antenna to antenna should be good for 30 miles plus.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 08/28/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
With the switch to HD reception became iffy for to many from Sutro tower in San Francisco. The FCC requested that the tower be raised. It's now almost 1,000' high and 1,800' above sea level. So raise your RV antenna. [emoticon]
wildtoad
Blythewood, SC
Posted: 08/28/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
OTA TV reception has ALWAYS been hit or miss. In older days you could have a good picture, light to heavy snow, ghosting, sound but no picture. Now you can go from perfect picture to nothing, pixelating, or other issues. All on a nice sunny day or cloudy or stormy. Just the nature of the technology. Sat works ok but even with that you have issues with trees, hills, buildings.
* This post was edited 08/28/19 02:18pm by wildtoad *
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
crawford
Dandridge Tenn.
Posted: 08/28/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
So what is being said the old system was better right?
CA Traveler
The Western States
Posted: 08/28/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Old had longer range with decreasing quality - remember the snowy picture? Digital is basically you have it or not.
But the US was lagging in picture quality. But now we have HD, 4K etc. I was fine with SD until I had HD. Now I'm fine with HD and don't think I need 4K but...
Since DTV is scheduled to drop all SD transmission in Feb 2020 I'll again be at the bottom - but I watch SD about as much as I stream TV.
wildtoad
Blythewood, SC
Posted: 08/28/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
No, the clarity and the available features, sub channels, etc of the digital systems is far better (once you get a good signal). Just saying that OTA is and always has been an iffy proposition.
RJsfishin
Winston Or.
Posted: 08/28/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
if you 75 miles to the transmitter, the old way was much better. A little snow doesn't bother near as much as blocking out.....the difference between watching it and not watching it !
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
 > New TV reception
