RV.Net Open Roads Forum: Travel Trailers: Tires
Bobbyg2013
Arizona
Posted: 08/28/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm getting quotes for tires for my 26'TT for both 6 and 8 ply. The brand Master Track keeps coming up. Was quoted $325 OTD for 8 ply which seems very reasonable. Any comments or experience with this brand?
cekkk
Southern Nevada
Posted: 08/28/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Posted in wrong forum.
Wbile I am unfamiliar with this brand of tire, I did notice that it shows a maximum tire pressure of 50 psi. Recommended tire pressure for other tires is generally 65 lb. That would steer me away from it unless I knew a whole lot more about that brand.
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
BobsYourUncle
Calgary Alberta Canada
Posted: 08/28/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
If it says China on them run away.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
lmpres
New Hampshire
Posted: 08/28/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Go Goodyear Endurance!
CALandLIN
SC
Posted: 08/28/19 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
New at shopping for RV trailer tires? 1st, determine the minimum acceptable size and load capacity. You'll find that information on the vehicle certification label, tire and loading placard and in the vehicle owner's manual.
The current terminology for the ply number within a tire is "ply rating". The ply reting is linked with the tire "load range" lettering system for LT and ST tires and "load index' numbering system for all other tires.
Vehicle manufacturer selections for original equipment tires for RV trailers are based on the load capability of the certified GAWR for each individual axle displayed on the vehicle certification label. The OE tires set the minimum standard for all replacement tires. Tire industry standards require replacements to povide a load capacity equal to or greater than what the OE tires provided.
* This post was edited 08/30/19 12:00pm by CALandLIN *
time2roll
Posted: 08/28/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
Shop speed rating first. Then price. I think you will be looking at Goodyear Endurance or Carlisle Radial Trail HD.
Ply rating is obsolete. I would not touch a load C if a Load D was available in my size.
Either way get tires that cover the full trailer GVWR.
675w Solar pictures back up
West & above Bishop, California
Posted: 08/28/19 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, get LR Ds and a 81 mph speed rating. And your post is fine...no help or support needed.
1492
Arlington, VA
Posted: 08/30/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
JIMNLIN
Oklahoma
Posted: 08/30/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
The only ST tires I would recommend is the..
Providers
Goodyear Endurance
Carlisle HD
In that order.
These are the new gen higher speed rated ST class tires.
The Providers have been out since the '10 era and have the time and miles and have a good service record.
Endurance...made in the USA and has been out 2-3 years now and is popular. No issues so far.
Carlisle HD....its also been out around 2-3 years and no bad reports so far.
Master Track ?? From the looks of the tread pattern its another of the many off brand name ST class tires out here.
dadnjesse
home
Posted: 08/30/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have always ran LT tires on my trailers. If you go over to the Montana Forums they recommend the Sailun's
