RV.Net Open Roads Forum: Fifth-Wheels: pulling fifth wheel with f250 supercab 6.2L engine
 > pulling fifth wheel with f250 supercab 6.2L engine
wiredgeorge
Texas Hill Country
Posted: 08/30/19 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 5th wheel that weighs about 10K lbs loaded and pulled it easily with my 96 F250 w/7.5L / automatic. You will have no problems as the 6.2L likely has more giddy-up than the ol' 460.
wiredgeorge Mico TX
2006 F350 2002 Keystone Cougar 278EFS
2006 GL1800 Roadsmith trike
Dave H M
IL
Posted: 08/31/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
try it out, I think you will be pleased since you apparently are not anti gas.
I have been pulling my 10K loaded fifth wheel with the 6.2 since 2012. Yank it thru the smokies at least once a year.
If you do not have the 4.30 diffy you will probably need to drop it down one gear quite often. Have fun out there.
cummins2014
Utah
Posted: 08/31/19 07:48am Link  |  Quote  |  Print  |  Notify Moderator
MarkTwain wrote:
1. Get 16 inch rims and G rated tires
2. Get a long bed truck
3. Buy Diesel truck with a Exhaust Brake
4. Contact Transfer Flow in Chico ca. To replace your stock fuel with an auxlilary larger fuel tank. 60 gal or larger.
You forgot to mention B&W, Mobile Suite , Ram truck, and whatever he's does do not get an Andersen hitch , OH, or Curt hitch . [emoticon]
RSerendipity
SE Pa
Posted: 08/31/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
You should be fine. Just towed my KZ Durango 281RLT @ just under 10,000 lbs over 5 major passes in Colorado with my F250 6.2 w/3.73 elocker rear. We were not always the fastest but made it over all without issue.
Enjoy your new Fiver.
goducks10
There
Posted: 08/31/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Your biggest concern will be getting the Reflection 150 series to sit level. It's a "Made for 1/2 ton" 5th wheel so the front over hang is lower than most.
Pine Barren
Northwest Florida
Posted: 08/31/19 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
You will be fine. I pull our fifth wheel with same truck. Yes it does pull a lot better than travel trailer does. We had only travel trailers for years and got our fifth wheel a year and half ago and will not even think about going back to travel trailer. We have pulled it in smokies and no problems
* This post was edited 08/31/19 06:07pm by Pine Barren *
camperfamily
New Jersey
Posted: 08/31/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Get your new camper and go camping like others said.
2011 Cougar 322QBS
2007 Pilgrim 278BHSS (Sold)
2013 F350 CC LB 6.7
2002 F350 CC LB PS (Retired)
B&W Companion Hitch
SugarHillCTD
Sugar Hill, NH, USA
Posted: 09/03/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
You will be OK.
Our 5th is 6900# dry and we easily pull it with our 2012 Chevy 6.0 gas.
Diesel? G rated tires? The OP isn't asking about pulling a 40' trailer.
pyoung47
MO
Posted: 09/04/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
You will be fine. Diesel trucks are great but overkill with that fiver. Avoid the G rated tires, since they may induce a very rough ride on a unit that small.
zenasboy
Southern Indiana
Posted: 09/04/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
As others have already said, you'll have no problems. Earlier this year I got rid of our '02 F350 7.3L for a new '19 F350 6.2L w 4.30 gearing. Tow a fully loaded 12K# Grand Design 303RLS 5th wheel. I love it! Sure, it revs up when going up steep hills but I've never once felt it to be lacking power or struggling. So far after towing around 2000 miles since June, it's averaged right at 8mpg when towing.
