RV.Net Open Roads Forum: How to deal with grease on ball of receiver
Search only in Towing
Open Roads Forum  >  Towing
 > How to deal with grease on ball of receiver
1ed
Northern California
Posted: 08/28/19 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Once you have grease on the ball, how do you cover while in the campground ? It seems that grease was all over the place...Will the rubber ball hitch cover work or are there better ideas out there? Thanks Ed Life continues to be a learning experience .
bob213
Fresno, CA
Posted: 08/28/19 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
I tie one of those (forbidden in CA) plastic grocery bags over mine. If staying longer than a day or two I have a receiver mounted on my A frame(by the battery) and I turn my hitch over and lock it onto that.
4aSong
Northwest Arizona
Posted: 08/28/19 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have used a tennis ball, just cut a hole large enough to slip over the ball. Another option is that people have used wax paper instead of grease on the ball something I have never tried.
M & N
Tundra TRD V8 4x4 w/Leer Shell
Lance Model 1985 - The Kramalot Inn
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
MitchF150
Puyallup, WA
Posted: 08/28/19 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
I pull the hitch head and lock it into the trailer tongue. Problem solved and no busted skin on the shines or grease on the legs.. [emoticon]
Mitch
Posted: 08/28/19 11:12pm Link  |  Quote  |  Print  |  Notify Moderator
More seriously, you don't need to grease your balls. Never wore my balls or ball holders out in a lot of days trailering all kinds of trailers.
cavie
Posted: 08/29/19 05:16am Link  |  Quote  |  Print  |  Notify Moderator
You've never seen a coupler worn thru? You've lead a sheltered life. LOL
JIMNLIN
Oklahoma
Posted: 08/29/19 05:32am Link  |  Quote  |  Print  |  Notify Moderator
When I had my construction business we kept two bumper pull cargo trailer as job site tool trailers. I ran a eight state area so those trailers saw lots of use. The 20 footer had two couplers replaced because they were worn beyond specs. They get thin on top and usually break through.
I use plastic slip on ball covers. I've found for my use I have less issues with grease getting where its not wanted.
DutchmenSport
Indiana
Posted: 08/29/19 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I used a 4 inch PVC end cap with the screw end cap. It fit perfectly over the ball. I then had a cloth bag with draw strings I'd slip over the hitch and end cap, so if driving down the road the cap would not fly off. I also kept the cap and cloth bag over the hitch when detached from the truck and stowed away. Because the end cap did not have to "forced" over the ball, and because it was actually bigger than the ball, grease on the outside of the cap was never a problem. It always stayed inside the cap. If we were at a campground and I knew the truck was not moving (like a short week-end), I'd just put the cap over the ball without the bag.
dodge guy
Bartlett IL
Posted: 08/29/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I used to tie a plastic bag over the ball. Then I found it was just easier to put it in the front storage compartment. Then I wouldn't have to run into it.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JRscooby
Indepmo
Posted: 08/29/19 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I also lock the ball in coupler when camping. This controls the spread of grease to where it does not belong, plus reduces the amount of dust that will collect on the grease/ball.
To use grease or not. I tried wax paper. When I loosened the latch so it would close I had play as the paper wore out. A big hammer will distort the coupler. I don't think many will pull their RV enough to wear the coupler, but how often do we have threads "Can't get coupler off ball"?
