RV.Net Open Roads Forum: Class A Motorhomes: Balancing tires, what's best?
 > Balancing tires, what's best?
supercub
Modesto CA
Posted: 08/29/19 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Getting new Toyos put on the motor home tomorrow. What's better balancing beads or spin balancing? What are the pros and cons ??
johnhicks
Wandering below the Gnat Line
Posted: 08/29/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Centramatics work great.
-jbh-
ppine
Northern Nevada
Posted: 08/29/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
spin balance. I have had good luck with Toyos.
MountainAir05
New Mexico
Posted: 08/29/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I like the balance beads from innovative balancing. Use them on two sets, could not ask for more for me. If you get mud , snow in the tread, they re-balance themselves. When you sling it out they re-balance again. I think the beads are less in cost.
The Centramatics also are good.
Tom/Barb
Oak Harbor, Wa
Posted: 08/29/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Ours were spun,, no problems
DFord
Near St Louis, MO
Posted: 08/29/19 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure what size tires but I prefer to have my tires balanced the "Vibration Control System" made by Hunter Engineering. The GSP9700 is a road force wheel balancer that tests the tire for high or hard spots on the tread. Most new car dealers use them to balance the tires on their vehicles. Many truck tire shops also use them. I've tried the CentraMatics without any luck - they're setting in my garage now - wasted money. I dislike the idea of throwing bags of crystals/beads inside tires to balance them - every time you start, the beads have to redistribute themselves as you get going.
Road ForceĀ® Elite Diagnostic Wheel Balancer
GSP9700 Locator
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
larry cad
ohio
Posted: 08/30/19 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Times 2. Had mine for several years over 3 sets of tires and never a problem.
Our Travel Blog
Airdaile
On The Road
Posted: 08/30/19 05:44am Link  |  Quote  |  Print  |  Notify Moderator
If they offer you Equal, make sure they put the correct valve stems in to filter out the sand.
rgatijnet1
Posted: 08/30/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
If you use the balancing beads, make sure they use the ones for the RV tires which DO NOT need special valve cores. The beads can also be reused in the next set of tires.
journey indiana
indiana
Posted: 08/30/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Spin balance. The beads/centramatics will cover up any problem that you might have with the tire or the rolling hardware. Most quality tire shops only use the beads in emergency situations, when changing a tire out on the highway, where a spin balance isn't possible.
Good Luck,
Journey Indiana
