Grey Mountain
On the rez somewhere in Indian Country
Our Norcold 1200 fridge will not run off propane or generator. Workds fine on shore power. Had this problem last year; RV fixit guy checked it out, said it was working fine. Nopo.
Any suggestions? Still considering switching out with a residential fridge.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
rdhetrick
That's very odd that it works on shore power but not generator. The 120v supply to the fridge shouldn't care (or know) whether it's coming from the generator or shore.
Have you verified that you are getting 120v at the plug that the ref plugs into while on the generator?
Of course that doesn't address the propane side, but it might point to an electrical problem outside the ref that could have an influence on the 12v system that the ref controls run off of - like converter/charger/inverter.
Rob
2005/06 Mandalay 40E Full Time
2015 Jeep Grand Cherokee
Tyler0215
Iowa
Those darn refrogerators
belairbrian
Alabama
Tyler0215 wrote: Those darn refrogerators
Yeah, when they break, what is an evil witch to do with a handsome prince.
Seriously, though. Sounds like maybe you only have 12v to the control circuits on shore power. Not sure why that would happen but as said Shore A/C and Generator AC should be the same. No 12v when on battery would stop propane from working.
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison
2009 Chaparral 278DS
Reese 16K Slider Hitch, Prodigy 3 BC
USAF Retired
WAR EAGLE
ajriding
st clair
Your generator must have electrical issues.
No flame from propane could be many things.
could be blocked tubes between the tank and the flame.
Could be wasp got in
could be a bad regulator
or a sensor went bad
or the thermocouple is bad or bent
lack of DC power to fridge
blown fuse
blown circuit board
could be fridge is on the last leg - the AC power might make more heat than the gas flame (did you confirm you do not have a flame) and the flame is just not enough to do any good.
Old-Biscuit
Verde Valley
When on generator check that you have 12VDC ......NO DC/No workie on AC or propane
doxiemom11
Somewhere between MI and TX
Could be a bad circuit board. We have had our work on electric and generator, but not propane. The circuit board was the problem. Replaced and all worked fine.
Grey Mountain
RV fixit guy says it may be a transfer switch issue. Taking it in in a few weeks.
I think I got metric gremlins in the electrical system last time I went to Canada.
GM
Grey Mountain
"Refrigerator" is a copywrited trademark and can not be used willy-nilly. That's why I compromised with "refrogerator."
Anyway, gimmee a break. I'm just a poor Injun tryin' tomake his way in a white man's world, what with a mission school education and a reservation upbringin'. What d'ya expect anyhow.
Send me free stuff. Preferabley a new refrig..., ah, a new refrogrator.
GM
edited 08/30/19 07:54pm by Grey Mountain *
dougrainer
Carrolton, Texas
ALL you have to do is fire the Genset up, open up the rear Access door to the refer and plug in a 120 volt light or appliance to the 120 refer receptacle. IF the Appliance operates, your Transfer is OK. IF the Transfer was a problem 1/2 of your 120 electrical in the RV would be dead. Doug
