RV.Net Open Roads Forum: Tech Issues: Refrogerator Problem
 > Refrogerator Problem
Grey Mountain
On the rez somewhere in Indian Country
Posted: 09/17/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
RV Fixit guy says I have a bad breaker in the inverter. That is what is causing the fridge problem. Options are to ship the unit to Xanax to be fixed or replace it. I opted to have it replaced.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
STBRetired
I-80 and I-55
Posted: 09/17/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, but that makes no sense. Why would a bad breaker in your inverter keep your fridge from working on propane? The inverter should have nothing to do with your fridge. Your inverter should be in pass thru mode when on shore power or if the generator is running.
The inverter may indeed have a bad breaker, but replacing / repairing that will not solve your fridge problems.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Grey Mountain
Posted: 09/18/19 03:35am Link  |  Quote  |  Print  |  Notify Moderator
All I know is what the Fixit Guy told me. As I have stated before, when it comes to issues such as this, I am an excellent wood worker.
GM
maillemaker
office
Posted: 09/19/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I would think a bad breaker would stop providing 110V to the fridge, but could still be providing the 12V it needs to run on propane.
But, you should have this problem on shore power or generator.
And, you can easily test by testing for 110V at the refrigerator plug, and by flipping the breaker to ON.
On shore power or generator power, with the fridge breaker ON, you should have 110V at the power socket where the fridge plugs in.
On my rig you can access this socket behind the outside access hatch.
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
Puddles
Lafayette, Indiana
Posted: 09/19/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
belairbrian wrote:
Tyler0215 wrote:
Those darn refrogerators
Yeah, when they break, what is an evil witch to do with a handsome prince.
Seriously, though. Sounds like maybe you only have 12v to the control circuits on shore power. Not sure why that would happen but as said Shore A/C and Generator AC should be the same. No 12v when on battery would stop propane from working.
Spelling critics, remind me of those kite eating trees... they are everywhere!
HTML
Grey Mountain
Posted: 09/21/19 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Got the unit back yesterday. Fixit folks replaced all four batteries; replaced the Xantrax Freedom 458 inverter. Apparently the issue with battery charging and also with the fridge are inter-related. I am checking the unit now to make sure everything is working as it's supposed to.
GM
Grey Mountain
Posted: 09/21/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Fridge is now working as it should.
Thanks for all the replies and suggestions.
GM
