RV.Net Open Roads Forum: General RVing Issues: Parking motor home on pavers
 > Parking motor home on pavers
RRTom
California USA
Posted: 08/30/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
We park our 30' motor home on a gravel driveway at home. We are thinking about putting down pavers of some sort. My main concern is if the pavers are suitable for that much weight. GVWR is 18,000 and we do keep fuel and fresh water tanks full, and we keep it ready to go except for food. Any advice, suggestions, "gotcha's" to watch out for?
2020 Georgetown GT 31LS
Ductape
On the Road
Posted: 08/30/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
There are variations in quality, some pavers are cheap and easily crack. Get some rated for vehicle use, not just walkway cheap stuff from the home improvement store.
Biggest is the underlying foundation plenty of gravel and rock dust well compacted is called for. The right preparation depends a lot on local soil conditions, I’d seek out some professionals and get quotes and recommendations on the job. Measure twice, cut once. You don’t want to do this job over.
49 States, 6 Provinces, 2 Territories...
Sam Spade
North Central Florida
Posted: 08/30/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
IF.....you think you are likely to keep an RV for a fairly long time.....I think that pouring a reinforced concrete pad would be a much better option.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
azdryheat
Tucson, AZ
Posted: 08/30/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
This website says that pavers can withstand 8,000 pounds per square inch before materal failure.
https://www.installitdirect.com/learn/top-paver-misconceptions/
This website says use 4 inch minimum thickness pavers for busses:
https://www.belgardcommercial.com/resources/design_solutions/designing_the_pavement_system
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
pennysmom09
Delaware
Posted: 08/30/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
We parked our fifth wheel and truck on our pavers, and although the pavers did not break, after a few years they did sink a bit under pressure.
Nancy and Doug
2015 KZ Durango 325RL FW
crcr
US
Posted: 08/30/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Full thickness pavers in our area are IIRC, 2 3/8" thick, and are used for driveways as well as walkways.
Beyond the thickness and quality of pavers, the most important factor is the substrate preparation. When contractors install them for vehicle traffic, if done correctly, they install a fairly thick layer of ABC (mix of dirt, sand and rocks that is used for base for roads), don't recall the thickness, maybe 8"? Not sure, I would suggest you research that).
Next they pack the ABC with a vibrating packer and then a heavy roller machine, then they screed several inches of find sand on top, then lay the pavers. Next, spread fine sand or preferably silica sand on the pavers and broom in around so it fills in the designed narrow gaps between pavers to lock them in. Then they run the vibrating packer all over the pavers to settle the pavers and the sand between them.
For walkways and patios only, some contractors put some ABC down first, then fine sand. But some just level the ground, then run the vibrator over it to pack it, then apply fine sand and screed it and lay pavers and don't bother with the ABC.
I would be very careful with picking a contractor for this, since you plan to park a motor home on it.
PastorCharlie
NC
Posted: 08/30/19 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
To limit cost one could build 3'X 3'forms where the wheels sit when parked and use plenty rebar and pour your own pavers as thick as you desire to support any weight. Leave the rest of the area with gravel. Mine parking area is washed decorative gravel and I use 3/4 treated plywood cut in half, both directions, and placed at areas where the wheels rest. I painted the plywood with good quality exterior oil base paint...last for years.
theoldwizard1
SE MI
Posted: 08/30/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Long term (weeks/months) storage on pavers are likely to cause them to subside/sink especially during rainy weather, even with the best of base preparation.
Parking on top of something like plywood that will distribute the load over a larger area works.
JoeH
Apollo Beach,FL
Posted: 08/31/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Our coach weighs 40,000 lbs and we park on our pavers with no issues. Been doing it for years.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Cobra21
minnesota
Posted: 08/31/19 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Our freinds like their paver driveway. When he backs up, he knows exactly where to stop. He feels the dip for every tire, and the rig won't roll away.
