RV.Net Open Roads Forum: Found a new way to test brake wiring and magnets
 > Found a new way to test brake wiring and magnets
joshuajim
Mojave Desert
Posted: 08/31/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
A rat chewed off one of my brake wires. I repaired it and wondered if any other places were chewed. After pondering it for a while, I turned off the converter, unplugged the breakaway switch and hallelujah the Tri Metric indicated 12 amps of draw.
Now this will not test the plug or guarantee that some other wire had some teeth marks, but it is a quick and easy way to check.
RVing since 1995.
joebedford
Finally back home in the north
Posted: 08/31/19 10:25am Link  |  Quote  |  Print  |  Notify Moderator
I've done the same myself but I never got to 12A.
DFord
Near St Louis, MO
Posted: 08/31/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
3 amps per brake is normal maximum draw for electric brakes. At 12 amps, I'm figuring you've got 4 brakes.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Matt_Colie
Southeast Michigan
Posted: 08/31/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I used to get out a compass and have DW hit the brake peddle. When I held the compass near the brake, the needle would swing. If it didn't, I knew I had found a bad brake.
I do hope you found all the chewed wires. I hate that.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/31/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
*** The compass tickled me. Great abstract analysis !!!
joshuajim
Mojave Desert
Posted: 08/31/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
The bath fan and some other parasite loads were still on. But close enough for me.
RCMAN46
NorthWest
Posted: 08/31/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
That is what I love about my Prodigy P3. It has a diagnostic function that I use every morning before I start a trip.
With four brakes I have found it is 1 amp per volt applied. My max setting when I use the manual lever is 7.5 volts thus I should read about 7.5 amps with full lever travel for my setting.
rjsurfer
North Carolina
Posted: 08/31/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
How do you initiate this test, or is done automatically on power up?
Ron W.
* This post was edited 08/31/19 02:01pm by rjsurfer *
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
RCMAN46
NorthWest
Posted: 08/31/19 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
This is how to get current reading from a P3 controller.
Matt_Colie
Southeast Michigan
Posted: 08/31/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
My coach is way too old for that.
The brake control Kelsey Hayes and is Teed into the rear brakes and is activated by the brake pressure. I like it because it actually tracks the applied brake pressure.
Maybe I will look for something newer when the flints where out.
-OOPs wrong technology.
Matt
