RV.Net Open Roads Forum: Class C Motorhomes: Replace GENERAC generator in a Gulfstream
 > Replace GENERAC generator in a Gulfstream
VA-Apraisr
glen allen, VA
Posted: 09/03/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
I spent $2000 having my 2004 Generac completely rebuilt last year; but, was a lot less than buying a brand new unit north of $4000. It's all in how you consider "cheap repair". Good luck.
enblethen
Moses Lake, WA
Posted: 09/03/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Look around for a small engine repair shop to rebuild yours!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
crawford
Dandridge Tenn.
Posted: 09/07/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Generac Power Boss 5600 Watt Generator Briggs & Stratton 10 hp Engine Carburetor
Brand New · Carburetor
$18.99
Save up to 10% when you buy more
Change from a c class to a A class Georgetown 07 triple slide
BillHoughton
West of the Mississippi
Posted: 09/07/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I occasionally fantasize about replacing the Onan generator in our rig with a Honda - I've had occasion once or twice to use portable Honda generators, and you can't hear them running when you're standing next to them!
Matt_Colie
Southeast Michigan
Posted: 09/08/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
At one time Honda made two great RV generators. 4010 and 6010 were great packages.
Notice I said WERE.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Bordercollie
Garden Grove, CA, USA
Posted: 09/08/19 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I just had the Onan 4000 genset and it's fuel supply system gone through by a well recommended generator shop. Cost was $794. Also replaced two 6volt 4 year old house batteries. Good advice is to run generator for two hours per month with AC on for a load to keep it running reliably. Also, house batteries need to be kept charged and with electrolyte covering the plates, use distilled water and rubber bulb filler. Keep terminal connections clean. Check voltage with digital multi-meter while resting and while running the chassis engine or RV generator. Worth being a little obsessive for reliable genset operation.
Bird Freak
Dallas Ga.
Posted: 09/09/19 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I know this sounds strange but check Amazon. They have several carbs for Generac.
I have bought several carbs from them for other things and all have been good.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Rawicklund
Louisiana
Posted: 06/23/20 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
My 1st post so I’m probably doing something wrong, and I’m uncertain how to address this to the OP.
Anyway I’m trying to see if OP was able to solve his problem. I have the same genset with the same B&S V Twin engine....still get most parts but some, like carb are obsolete.
My carb was also gummed and not working when I got my new to me MH...2002 Newmar.
I was able to repair carb and get unit running, but now I have hard start issues due to what I think is low compression. I’m trying to weigh repair vs replace engine, but I’m unable to find a compatible replacement.
Unit has 525 hrs according to meter, so I think it would be economical to replace whole engine. But other then model # I have no hp specs on engine. Local small engine shop was no help.....#303775-0110-01.
Anybody know a source for replacement engines?
Thanks in advance
Ray
kwplot34
home
Posted: 06/24/20 01:27am Link  |  Quote  |  Print  |  Notify Moderator
525 hrs is pretty low, it should not be low on compression. Have a compression test and a leak down test done on the motor.
crawford
Dandridge Tenn.
Posted: 06/24/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Did he check valve lash ?
