RV.Net Open Roads Forum: Class A Motorhomes: outside tv HELP
 > outside tv HELP
sssooo
Ohio
Posted: 08/31/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
my new to me 2018 bounder 36H I cant get the outside tv door to open I unlock it the lock flips out but it wont open I don't think there is a secret way to open it!!!
HELP scott
RedRollingRoadblock
Oregon
Posted: 08/31/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Did you push the button after the latch pops out?
Wherever I happen to park
Posted: 08/31/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Alas there is but it depends on where the lock it.. If the door opens UP and the lock is a TRI-Mark then the latch is at the bottom and you can slide under with a LONG screwdriver and depress the striker bolt.. WARNING It may fall apart when opened so have fun catching.. If it opens to the side you may not be able to do this.
The problem (IF IT IS A TRI_MARK) Note that this is specific to trimark
On the inside of the lock is a bell crank lever (Basiclly a more or less flat metal bar) the handle pushes (Down or to the side) on one end and the other end then pivots UP (or to the other side) pulling the striker bolt.
The screw is loose is option 1
option 2 is the striker bolt broke and needs replacement.
Now.. I know a shop that makes replacements for 45 bucks a pop (Senece Engineering or Seneca Machening. not sure which) Seneca SC) but.. unless the bolt is the same size as mine he does not have a pattern.
Home is where I park it.
sssooo
Ohio
Posted: 08/31/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
I got it I think that it was closed for so long that the rubber gasket was stuck to the door my bad
scott thanks all
ArchHoagland
Clovis, CA, USA
Posted: 09/01/19 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
Glad to hear you got it open, thanks for the update.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
 > outside tv HELP
