RV.Net Open Roads Forum: Tech Issues: AC problems again
 > AC problems again
Lynnmor
Red Lion
Posted: 09/02/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
I didn't see where the input voltage was checked.
enblethen
Moses Lake, WA
Posted: 09/02/19 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Even if they come with new boards they still need to be set up.
I didn't see whether this is same issue as you had with original AC units that were replaced.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Posted: 09/02/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Yes and no on set up. Zone 1 is a default and will be the front unit. Zone 2 MUST be set and will be bedroom. If Zones NOT set up, then the system will not function at all. So, his zones are set correct. The ONLY other set up that he would need is to tell it has a furnace. But if not switched to furnace it would have no bearing on his Cool operation. Doug
12th Man Fan
Flower Mound , Texas
Posted: 09/02/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Both AC's had worked just fine B4 I left Texas. This was a new problem that developed while in Colorado high altitude. Sorry I didn't clarify that sooner.
I switched the sensors this morning and as soon as I turned on the front AC on which was the unit I put the bad sensor in gave me an E5 error which is open ckt or out of range freeze sensor. So far the back unit is working as it should.
I pulled the bad sensor out again and sure enough it was open ckt when I checked it with a VOM meter. I wish I had checked it before I sent to the trouble of installing it in the front unit.
New sensor on order.
Thanks everyone for you help. I know just enough to be dangerous on things like this.
I am getting too old for this kind of stuff. Four trips to the roof! Yuck.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
enblethen
Moses Lake, WA
Posted: 09/02/19 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Let us know on this post as what happens!
12th Man Fan
Posted: 09/03/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Well the AC worked all day with no issues so the problem was the freeze thermister.
Thanks all for your help.
enblethen
Moses Lake, WA
Posted: 09/03/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
 > AC problems again
