RV.Net Open Roads Forum: Should I put my Mobley SIM in another hotspot when parked?
 > Should I put my Mobley SIM in another hotspot when parked?
MrWizard
Traveling
Posted: 08/31/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
log into your mobley at http://attwifimanager or 192.168.1.1
goto settings left hand column
goto mobile broadband
then click on SIM Security over in the main window
i think the default access code for a NEW unlocked SIM is eight ZEROS "00000000" no quotes
i changed the 'lock code' and then unlocked it, so i could move it back to the Mobley if the need arised
if it was locked and the netgear died, then it would not work in the Mobley
changing the lock code means ATT can NOT lock it
* This post was edited 08/31/19 09:59pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
jcpainter
Crossville, TN
Posted: 09/01/19 03:52am Link  |  Quote  |  Print  |  Notify Moderator
MrWizard wrote:
i put my Mobley SIM into a NetGear hotspot wifi router
since it was already in the Netgear when ATT did their SIM lock stunt, it was not affected, and when i learned what was going on, i logged in and changed the lock code on the SIM from the default to one of my choosing, even IF i put in back in the MObley, ATT can not change it
the NetGear is superior to the Mobley, more range better signal etc..
i would read up on the unlocking of the MObley SIM, and get that done before investing $$ in something you might not be able to use
Excellent advice!
jcpainter
Crossville, TN
Posted: 09/01/19 03:54am Link  |  Quote  |  Print  |  Notify Moderator
wanderingaimlessly wrote:
GordonThree wrote:
Did AT&T finally get rid of the ridiculous stipulation that the service was for use in an in-motion vehicle only?
My understanding is that the Mobley was a "dumb"device, and ATT could not tell if you were using it outside the vehicle. The newer units being sold now, they can tell.
Correct, that's what I've read also.
magicbus
Nantucket Island, MA
Posted: 09/01/19 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Even if your SIM is locked just unlock it. See this post for step by step instructions.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
ralphnjoann
Colorado
Posted: 09/01/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Dave
Does this process still work? Has anyone done it recently?
vermilye
Oswego, NY, USA
Posted: 09/01/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
ralphnjoann wrote:
Dave
I got the PUK codes (both of them) from an AT&T rep (over the phone) 2 days ago. Moved the SIM to a Nighthawk, went through the procedure to lock up the SIM, used the PUK code to unlock it & put in my own code.
The Nighthawk is a big improvement over the Mobley, although I'll keep the Mobley in a drawer just in case...
Another excellent tutorial on the problem & process is at the Technomedia site: Mobley Locked
Jon Vermilye My Travel Blog
My Photo & RV link blog
Naio
Snug as a bug in a rug
Posted: 09/01/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
You folks are amazing! Thank you so much!
Weirdly, I cannot access my Mobley either through http://attwifimanager or 192.168.1.1, although I have done so in the past. My Mobley is on and working. I am using it to post this.
I can call AT&T this afternoon, but I thought I'd just check first and see if you folks know what might be going on.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
magicbus
Posted: 09/01/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
About not being able to access your Mobley... May not apply, but when I am on my work VPN I can’t access my cell modem (my Mobley replacement) or my router. Are you by chance using a VPN?
Dave
jcpainter
Crossville, TN
Posted: 09/01/19 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you're connected to the Mobley and not to another WiFi source?
Naio
Posted: 09/01/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I'm sure I'm on the mobley, but pausing my VPN worked!
New problem. There is nothing called mobile broadband in the settings. The closest I can find is Network > APN > ATT broadband. That allows me to set a username and password, although there are not any preset ones. I'm not sure if I should do it, though, since I don't know if it is the thing you folks are referring to...
