RV.Net Open Roads Forum: Truck Campers: sway bar upgrade on 2002 F-350 dually
 > sway bar upgrade on 2002 F-350 dually
GULFMAN
MOORESVILLE, NC,USA
Posted: 09/03/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone upgrade sway bars front and rear on a 2002 F-350 4 wheel drive?
Was thinking about going with Hellwig.
Any feed back would be appreciated.
VehicleTrader94
Posted: 09/03/19 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2002 F-350 Crew Cab dually 4x4 with a diesel and have both front and rear Hellwig bars and weigh about 12k loaded. They help in corners and make the truck feel more tied together. It was a noticeable difference but not huge. The rear bar is not stiff enough for my liking. I still get rocking pulling out of uneven driveways. Truck Camper Magazine had an article that mentioned just this problem when they had bars installed on their rig. I believe it was Roadmaster they used. They were able to get a slightly thicker bar from another application that made a huge difference for them. I have not taken the time to research larger bars for my truck. I guess I should mention I started with factory bars front and rear before installing Hellwig.
I have front and rear Hellwig on a 95 F-150 2wd regular cab short bed that came from the factory with no bars. MASSIVE improvement and 100% satisfied. Just backing out of the driveway I could feel the difference in stability.
1988 Bigfoot C-11.5 on a 2002 F-350 DRW 4x4
Siletzspey
Shedd, OR
Posted: 09/03/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a Roadmaster sway bar on my 2015 F350 SRW 4x4 rear, and it made a huge improvement over the much-smaller Ford OEM sway bar. Roadmaster sells the sway-bar and drop-down bars separately, and their sway-bar works with the difficult-to-remove OEM drop-down bars if you already have them.
--SiletzSpey
northshore
northshore
Posted: 09/03/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I up graded my 2006 f 350 drw 2 wd with helwig front and rear sway bars. The Helwig were much much thicker and made a huge difference. I love how it handles now, and btw I haul a 2002 Lance 1130
Buzzcut1
Norcal
Posted: 09/03/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I put Roadmaster anti sway bars front and rear of my 2003 F350. They made a world of difference and they were super easy to install.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
GULFMAN
MOORESVILLE, NC,USA
Posted: 09/04/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your comments.
I sent a e-mail to Hellwig tech support Monday last week and never got a reply.
It looks like to update the rear sway bar on my 2002 i will have to lower the the fuel tank to get to the upper bolt on the left sway bar link it is inside the frame rail right up against the fuel tank.
Not sure if it is worth all that work.
Thanks and ever one have great day.
VehicleTrader94
Posted: 09/04/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I did not have to lower the fuel tank on mine. It was tight but I managed.
