RV.Net Open Roads Forum: Travel Trailers: outdoor shower help
 > outdoor shower help
Jebby14
Windsor Ontario
Posted: 09/03/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
hi all. last weekends trip I found I no longer have water to the outside shower (hot or cold) both handles turn but the water pump never kicks on and if the lines are already pressurized still nothing. assuming this is a kinked hose somewhere but any tips on where to start would be great. For what its worth I had water to the unit last trip so I know its a new problem and its not a lack of pressure but water all together.
Q: Whats brown and sticky???
A: A Stick....
Cocky_Camper
Rock Hill, SC
Posted: 09/03/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Take your shower head hose off and make sure it isn't clogged with debris anywhere.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
Hondavalk
Toledo
Posted: 09/03/19 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
X2
camperdave
northern, California
Posted: 09/03/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Any chance you forgot to open up the shut off valve at the shower head?
2004 Fleetwood Tioga 29v
Jebby14
Windsor Ontario
Posted: 09/03/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
ill pull the head and check for smutz just seemed strange to be that it would go from fine to nothing not fine to low pressure.
BB_TX
McKinney, Texas
Posted: 09/03/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a quick disconnect for the hose, make sure it is fully inserted.
Cocky_Camper
Rock Hill, SC
Posted: 09/03/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like something is clogging it. If that doesn't work, disconnect the house from the faucet and see if you are getting water from there also.
StarkNaked
West Seattle, WA
Posted: 09/03/19 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have in-line shut off valves for your outside shower lines? My rig does. Has someone closed the valves?
If it's a kinked shower hose, (and it's the type where the connection in inside where you can't access it from the shower box) you need to figure out where to access the hose from inside the RV.
Boband4
Wa
Posted: 09/03/19 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
My outside shower has a 1/8 turn on the actual water spray head (a twist ring on the sprayer) to turn rhe flow on and off. Certainly isnt marked, you just have to know it is there. Try twisting the bezel at the shower head to see if it is shut off. Be sure to point it away from yourself....dont ask how I know about that.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 09/03/19 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
“hi all. last weekends trip I found I no longer have water to the outside shower”
So when you sanitized the fresh water system prior to your trip departure, the outside shower worked well?
