RV.Net Open Roads Forum: Fifth-Wheels: Schwintek slide out of whack
 > Schwintek slide out of whack
Toolguy5
Columbia Station, Ohio
Posted: 09/03/19 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have a slide that is out of whack. I have tried running slide inane out 3 times to regime. I have also tried extending slide all the way and running it in and out 8 to 10 inches 3 times. I have also run it in all the way and extended it 8 to 10 inches 3 times.
Non of this has worked. It still is out of whack.
What can I do to get it back in time?
Dan & Patty
Miss Pickles the Pomeranian Princess
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2018 Jayco Northpoint 387 RDFS
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
Chris Bryant
Arden, North Carolina
Posted: 09/03/19 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Do you hold the switch down until it shuts off?
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Toolguy5
Posted: 09/03/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Yes
larry2c
Southern CA
Posted: 09/03/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure if this relates to your issue but I had an issue with my Schwinteck slide where it was noticeably "lagging" on one side and it would take multiple tries to get the slide in or out. Like you, the syncing did not relieve the issue. Took it into the shop and they determined that the cable going from the controller to the forward most motor was damaged and providing intermittent power. Cable was replaced and it has worked fine ever since (knock on wood!)
Outta my way, we're goin campin!
'18 Salem Cruise Lite 210RBXL
'11 F150 SCREW 4X4
neschultz
Eastern Shore of MD
Posted: 09/03/19 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Does the slide controller show any error codes? LCI has some nice info on their web site.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
ceasare
staten island
Posted: 09/03/19 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
go on you tube. there are videos on how to reset the slide using the controller. It was also explained in my owners manual but that was confusing. Had the same problem did the procedure and it has worked great since then.
Toolguy5
Posted: 09/10/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Called my dealer and he told me to put the controller in override. Then run slide all the way out and all the way in. Let it rest until led lights on controller stop working. Then try running it out and back in.
That appears to have fixed it.
