RV.Net Open Roads Forum: Travel Trailers: Water Pump while Boondocking
 > Water Pump while Boondocking
badercubed
Canandaigua, NY
Posted: 09/03/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ok, so here is the deal. While boondocking, we only turn the water pump on when it's needed. The last two trips, the pump has built up enough pressure for multiple people to brush teeth, to wash dishes and the flush the toilet numerous times. After a while, we notice the pressure going down and run the pump. It will run for about two minutes and give lengthy pressure again.
How and why?
2019 Apex Nano 208BHS
2018 GMC Canyon Crew Cab SLE
Been camping for 36 of my 37 years!
shastagary
minnesota
Posted: 09/03/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like your rv has a accumulator tank installed in the water system
rv accumulator tank
profdant139
Interesting!! I wonder whether someone installed an accumulator in your trailer. We put a small accumulator in ours -- it causes the pump to run less frequently, thus saving electricity. But it only holds about a quart. It sounds like yours holds a gallon or so?
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ScottG
Bothell Wa.
Posted: 09/03/19 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I put one in our last TT that held a gallon. I was able to flush the toilet 18 times before running out of pressure!
A two gallon would have provided even more time.
It doesn't cause the pump to run less overall though. It only causes it to cycle less.
* This post was edited 09/03/19 08:11pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Monterey, CA
Posted: 09/03/19 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Accumulator tanks a great mod for those without one.
badercubed
Canandaigua, NY
Posted: 09/03/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Learn something new everyday.
Camper was new from the dealer and we never talked about an accumulator tank, nor have I ever heard of one. It's great for when the Littles get up in the middle of the night or we come in late since the pump is under the bunks.
Huntindog
Phoenix AZ
Posted: 09/03/19 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
^^^^^ This.
The pump has a fairly high amp dray when it is running, but it's overall amp draw when boondocking is limited by the water supply. So it's total overall amp draw is not a big energy hog.. In fact it is far enough down on the list as to be insignifignant.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
trail-explorer
NM
Posted: 09/09/19 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
But, there's no conformation your trailer has an accumulator tank until you actually see it. There could a bad check valve in the pump.
Bob
Boon Docker
Posted: 09/09/19 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
A bad check valve would do the opposite of what the OP explained. The pump would start up and shut down over and over again without any tap being turned on.
gmckenzie
BC
Posted: 09/09/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but it does mean you can turn the pump off when you go to bed, pee 18 times in the night and not have the pump that is in the cabinet next to the DW's side of the bed run in the middle of the night waking up the DW.
[emoticon]
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
