RV.Net Open Roads Forum: Class A Motorhomes: 2 6v batters VS 2 12v
 > 2 6v batters VS 2 12v
Cocky_Camper
Rock Hill, SC
Posted: 09/04/19 06:24am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the house batteries in our Sea Breeze after getting 8 years out of them. It had to 6v in it. Just curious, why do some people run two 6 volts instead of parallel 12v?
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
harley-dave
ummm, where are we again..
Posted: 09/04/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Mostly because 2 large six volt batteries in series gives you more amp-hours than the 12 V batteries do. For example Our 6V Interstates have a rating of 220 AH (amp/hour) each where a 12V might give 80-90 AH each for a total of only 160-180 AH (example). Plus the deep cycle battery handles deep discharge and recharge better.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
2oldman
Ca
Posted: 09/04/19 07:13am Link  |  Quote  |  Print  |  Notify Moderator
6v v 12 2018
6v v 12 2017
6v v 12 2017
12v vs 6v.. which charge faster? 2014
12v or 6 Dec 2013
2- 12v or 6v June 2013
12v vs 6v batteries 2013
12v vs 6v batteries 2006
More 12v vs 6 2006
12v vs 6v 2010
Why 2 6? 2006
phemens
Montreal, Canada
Posted: 09/04/19 07:51am Link  |  Quote  |  Print  |  Notify Moderator
It might also depend on your use case. I initially started with a bank of 6v Trojan T-125's, but wasn't satisfied with the voltage drop on heavy inverter draw. I switched to Rolls-Surrette high capacity 12v (210AH) to help mitigate that issue for me.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1Kw solar, 500 AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
pianotuna
Regina, SK, Canada
Posted: 09/04/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
2oldman thanks for the links.
If a large inverter may be in use, 12 volt jars may have a slight advantage. Part of that may be due to the external series connection required for a 6 volt pair. Another part is 12 volt jars totaling up to the same amp-hour capacity have double the cell count, so each cell is working 1/2 as hard.
The downside is that as cell count rises the possibility of failure rises, too.
True deepcycle 12 volt may be more expensive per amp-hour.
Add some solar panels and your batteries may last even longer.
I'm a fan of AGM jars.
Regards, Don
tropical36
Southwest Florida_USA
Posted: 09/04/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Dave
Good answer, but keep in mind that pure deep cycle also comes in 12v sizes.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
tropical36
Posted: 09/04/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that two 6's in series, is just one big 12 and granted, it's big, but then if you only have room for four batteries, you now have just two big 12's, rather than four smaller 12's.
Usually and unless you find some really large 12's that will fit, the four 6's will still have more capacity.
They they found this out, with putting four 12's in golf carts for awhile and have since went back to using six 8's, so again, pure deep cycle comes in multiple voltages.
Then we have the AGM's and my preference and even though expensive, they're maintenance free and don't expel gas. Also the ones that I have, came with a 60 month, replacement warranty, so we'll see how that goes, in a couple of more years.
Mine are four 12v AGM's, neatly connected in parallel obviously and the main reason for going this route, was for keeping it OEM, like the connection diagram on the compartment door and not like we boon dock for days on end, anyway. No matter what, you'll need to run your genset occasionally to keep them up, anyway.
theoldwizard1
SE MI
Posted: 09/04/19 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Despite what the distributors and retail establishments tell you, marine/dual purpose 12V batteries are NOT true deep cycle batteries. The only commonly available TRUE deep cycle batteries are 6V golf cart batteries.
(12V deep cycle batteries DO EXIST, but they are hard to locate (typically special order) and very expensive)
Morro Bay, CA
Posted: 09/04/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Trojan isn’t a distributor or retailer, wizard. The T1275 is a true deep cycle 12 volt battery.
http://www.trojanbattery.com/product/t-1275/
tropical36
Posted: 09/04/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Where did you get this idea of 6v only, when you can go to Sam's or Cosco, and buy 8v golf cart batteries, all day long? Same for 12 golf cart batteries, but not so much now, since the industry quit using them for OEM. I'll take a look at Rural King, the next time I'm there for these, as well. As an added note, they haven't made 36v golf carts for years, but there's still many of them out there, including mine, for feeding the battery industry. With the four 12's golf carts, many have since installed the today's standard of six 8's.
Now, gels, are especially good and wouldn't mind having four 12's like these, installed in our coach.... 12v deep cycle gel
You're absolutely correct about marine batteries, not being true deep cycle, in any sense of the word.
* This post was edited 09/04/19 04:36pm by tropical36 *
