RV.Net Open Roads Forum: Tech Issues: Non stop fan on AC
 > Non stop fan on AC
lap527
Ocala, Florida
Posted: 09/04/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
We currently have 2 campers, both camplite, a tt and a tc. On both of our campers the fan on the AC runs all the time. If the AC is on then the compressor will come on and then shut off but fan stays on. Hmmm....why? Is it cheaper? Both of the ACs are Dometic, one a 9200btu and the other a 13.? In the tt it sure is loud. Inquiring minds want to know if anyone can tell me. Thanks!
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer Hauling 2014 Tri-glide Harley Davidson, recently added a 2016 Livin Lite 21RBS travel trailer. No Wood!No Rot!
Rgtopda
Gulf Breeze Fl.
Posted: 09/04/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the thermostat is on auto fan...Mine was doing it until i put on my cheater glasses and saw i did not have it on auto.
RGTOPDA
(Jimmy Buffett Fan)
2003 Newmar Dutch star
36 ft. Gulf Breeze Fl.
solismaris
Massachusetts
Posted: 09/04/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I can put up with "loud" a lot easier than "loud/silent/loud/silent/..." cycles. So my fan stays on. My thermostat has a switch for that though if I want to change it; I think most do.
David Kojen
lap527
Ocala, Florida
Posted: 09/04/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Rgtopda, but there is no auto fan on AC. On the ACs there is on, off and where you can adjust the temp of the AC.
camperdave
northern, California
Posted: 09/04/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
That's how the non-ducted a/c (direct controls, no remote thermostat) was on my old trailer. The one in my motorhome is ducted and the thermostat has an auto fan switch on it that will shut off the fan between coming cycles.
2004 Fleetwood Tioga 29v
Sam Spade
North Central Florida
Posted: 09/04/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Well then what you see is what you get.
I had to replace one of my A/C units and the new one is like yours.
But at least mine has high and low fan speeds.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
lap527
Ocala, Florida
Posted: 09/04/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys! Our fiver was ducted so now I know why. I do find that I sleep better with the noise because I don't hear anything from the outside. However, watching tv can be a bite. Knowledge is power!
LadyRVer
Posted: 09/04/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
My a/c in both the truck camper I had and the two travel trailers are not ducted.
The fan runs continuously and the compressor cuts on and off. No auto fan.
My fivers all had ducted air with auto and that sure made a difference.
DutchmenSport
Indiana
Posted: 09/04/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
My first 2 TT's were not ducked, and the air conditioners ran constantly. My 3rd TT was ducked and it cycled on-off. My current 5er has 2 AC, both ducked and they both cycle on-off. Because we have one in the bedroom area, I usually leave it in fan high mode. The cooling cycle kicks on and off, but the fan blows all the time. I have a hard time sleeping when the fan is constantly kicking on and off. Plus, s stated above, it drowns out noises.
hedge
Airdrie, Alberta, Canada
Posted: 09/04/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
That drove me nuts on my non-ducted as well. I installed a new control unit so I could control it with the thermostat. Toughest part was running the thermostat wire to the unit as mine was not ran from the factory.
The uTube vid below is essentially what I did except I used a standard battery powered house thermostat that I had already installed. Because I used a house thermostat I only have 1 fan speed though so I chose low.
https://www.youtube.com/watch?v=BR8To1Yt........Ovr2maYu9GS4LWQW2CR6J-ZjXGdWAraZLv8RldJU
2017 F350 Platinum DRW
2013 Adventurer 89RB
