RV.Net Open Roads Forum: Travel Trailers: Build Your Own Travel Trailer
 > Build Your Own Travel Trailer
JRscooby
Indepmo
Posted: 09/10/19 04:35am Link  |  Quote  |  Print  |  Notify Moderator
rjstractor wrote:
For a builder that wanted to build it literally from the frame up, a flatbed equipment hauler has the frame strength you need, especially the 10K+ GVWR ones.
If you or the OP need that kind of strength, how can you get by with a factory built TT, with a frame that has no where near that strength?
APT
SE Michigan
Posted: 09/10/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Factory built RV uses far lighter construction materials.
2017 Subaru Outback 3.6R
JRscooby
Indepmo
Posted: 09/10/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
You are right, a home built will likely be heavier. But if within the weight limits of the trailer not a issue. And the home built, using the heavier material, the house likely will be more rigid, no matter what frame it is on.
OTOH, a heavy built house, on a high load capacity machinery trailer? The TV better have a red oval, nothing with a blue one would have the capacity...
