RV.Net Open Roads Forum: Tow Vehicles: Goosebox vs. fifthwheel
Search only in Tow Vehicles
 > Goosebox vs. fifthwheel
hedgehog48
Posted: 09/05/19 02:55am Link  |  Quote  |  Print  |  Notify Moderator
If you were outfitting a new long bed pickup to tow a fifthwheel camper would you buy a nice fifthwheel hitch and spend the money instead on a Reese goosebox and ball combo? I’m liking the goosebox idea because removing just a ball doesn’t involve any heavy lifting. What are the pros and cons of both?
Learjet
Louisiana
Posted: 09/05/19 03:09am Link  |  Quote  |  Print  |  Notify Moderator
the only negatives I have heard with the Reese Goosebox is... having to add air to the airbag often, you have to raise the trailer higher when connecting/disconnecting to clear the ball and a litter harder to line up when hitching. If your truck has the optional air ride...like on the Ram...you can use that to lower the truck to make hitching easier.
I'm sure there is more....just wait for it [emoticon]
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Groover
Pulaski, TN
Posted: 09/05/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
If you have to frequently add air to airbag does that mean that it leaks down and you are likely to have damaged your rig by not having enough bed rail clearance?
Charlie D.
E. Texas-Orange
Posted: 09/05/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
deleted
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
BB_TX
McKinney, Texas
Posted: 09/05/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I think "add air to the air bag often" depends on your definition of often. I don't have the Goosebox, but do have a 5th Airborne air ride pin box with an air bag. And I add a little air at the first of each season and am generally good for the year.
kmac7800
Richland
Posted: 09/05/19 09:39am Link  |  Quote  |  Print  |  Notify Moderator
The "add air to airbag" was an issue with loose fitting(s) letting air out. Once they tightened the fitting up, all was good. This has not been a problem on their second generation.
If/when we move up to 5th wheel, the Goosebox is high on my list for the same reasons as the OP.
YMMV. Good luck.
//KMac
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 09/05/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Because it is a ball hitch many states require safety chains. Weight-be-dammed I would get a B&W puck mounted hitch.
Huntindog
Phoenix AZ
Posted: 09/05/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious.. What is the negative on safety chains?
I am considering this myself for our upcoming TH.
The thought of simply removing a ball, to get my bed back is very appealing.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2020 Silverado High Country CC DA 4X4 Big Dually.
BB_TX
McKinney, Texas
Posted: 09/05/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Only negative to the chains is having to reach into the bed to hook them.
Me Again
Posted: 09/05/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Think crawl in the bed to attach and un-attach them.
