RV.Net Open Roads Forum: Anti roll bars for fifth wheel with air ride.
 > Anti roll bars for fifth wheel with air ride.
LaundroKing
GALT, CA United States
Posted: 09/05/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
After installing Lippert center point air ride I noticed the trailer rolling a lot more in the corners and particularly with a cross wind. The way the system is set up, the air bags are interconnected, which allows them to bleed air from one side to the other. This tends to let the trailer roll even more in a long turn or strong cross wind.
I was wondering if anyone has installed or even seen anti roll bars for trainer axles. They are common place on tow vehicles, both front and back.
Mark
2005 Ford F250 6.0 PSD BulletProfed
2008 Hartland Sundance 30ft 5er, Flexair pinbox, Center point equalizer.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 09/05/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
If it was mine I would put check valves in the lines so the air can't tranfer, first I heard of anybody installing that system on a fw, How soft does everything need to be????
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 28' 5th wheel Travel Aire. Lots of fun.
ford truck guy
Pennsylvania
Posted: 09/05/19 10:53am Link  |  Quote  |  Print  |  Notify Moderator
I know a guy who installed the Centerpoint on his Redwood Fifth Wheel, he never once complained about it. In fact, he commented whenever anyone was discussing the expense of installing the Morryde IS....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
noteven
Turtle Island
Posted: 09/05/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Try calling Donvel to see if they have a valve that would work for you.
B.O. Plenty
Minnesota
Posted: 09/06/19 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I would disconnect the hoses between them and install individual fillers for each side so the pressure can no longer transfer.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Cummins12V98
on the road
Posted: 09/06/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
I had the CenterPoint system on my 07.5 Mobile Suites. Each side had a pressure gauge with separate fills. Bottom line the plates needed to be parallel to each other on level ground to be properly inflated.
Change to separate fills for each bag!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
jaycocamprs
Ringgold Georgia
Posted: 09/06/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
B.O.
I'd just put a valve in the crossover line. Open to fill then close.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
LaundroKing
Posted: 09/06/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Separate lines and gauges would centrally work. Check valves would only let you put air in and not out if you needed to.
The system works great to keep the trailer and things inside from bouncing around. I would do it again in a heart beat on any trailer.
Thanks for all the feedback.
B.O. Plenty
Minnesota
Posted: 09/06/19 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
jaycocamprs wrote:
B.O.
Good answer. Keep it simple.
B.O.
Cummins12V98
on the road
Posted: 09/07/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Simply LOOK at a CenterPoint OE install and you will see they have separate fill ports and gauges on each line. The Metal plates need to be paroles to each other for proper ride. That requires different pressures.
