RV.Net Open Roads Forum: Tech Issues: Battery Charging Problem
 > Battery Charging Problem
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/07/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Jennifer Koper
494 Norman Street
Posted: 09/08/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
my car won't charge but the charging brightness isn't pending on and i put it on a computer and got no codes..is there and relays or anything that could make it do this? or if the battery is totally shot could it be that?
enblethen
Moses Lake, WA
Posted: 09/08/19 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Jennifer:
What are you trying to say?
Car won't charge? Are you talking a toad will not charge from MH? Are you talking a car just will not charge? What do you mean about "charging brightness"?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MEXICOWANDERER
Posted: 09/08/19 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
  • Describe the car
  • Brand of /battery
  • Lifespan of battery
  • Are any warning lights lit on the dashboard
  • When cranking the engine all warning lights on the dash should light up. Do they?
  • How many miles does the car have on the odometer
Grey Mountain
On the rez somewhere in Indian Country
Posted: 09/17/19 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
RV fixit guy found one bad battery. Will replace all four. Batteries were replaced in May of 2018. Interstate will warranty all four and replace them at no cost.
FIxit guy also says there is a bad breaker in the inverter. Choices are to send it to Xantrax for repair or just replace it. Opted to replace it. He says the fridge problems are caused by that.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
MEXICOWANDERER
Posted: 09/18/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Insist on a USA Made breaker. I threw out my inventory of chinese pretend breakers.
Grey Mountain
Posted: 09/18/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Clarification: Replace the entire inverter; not just the breaker.
GM
Grey Mountain
Posted: 09/21/19 04:46am Link  |  Quote  |  Print  |  Notify Moderator
Got the coach back yesterday. Replaced all four batteries; replaced the Xantrax Freedom 458 inverter. Fixit guy says that will correct the charging problem and also the refrogerator problem about which I posted in another thread.
I am checking to make sure everything works as it's supposed to.
GM
Grey Mountain
Posted: 09/21/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Batteries are charging as they should.
Thanks for all the replies and suggestions.
GM
BFL13
Victoria, BC
Posted: 09/21/19 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Catching up on the story here---
1. So Interstate agreed that one bad battery would spoil the others, or ? They agreed the bank should have all four the same age/condition, so you should not just get one new one? (That would be the general notion among members here too)
2. What did you replace the broken Xantrex 458 with?
3. Your fixit guy actually has a clue, which is nice to see. Been some posts on here about how some fixit guys don't have a clue. [emoticon]
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
