RV.Net Open Roads Forum: Tech Issues: Honda 3000eu issue using a bonding plug
 > Honda 3000eu issue using a bonding plug
Jetstreamer
Milwaukee, Wisconsin
Posted: 09/05/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I made my own neutral ground bonding plug to use with my generator. I had it plugged into one of the outlets on the generator. When I went to use it for the first time, I had a spark and a bit of smoke very briefly come out from somewhere on the panel.
I immediately pulled the bonding plug out and the generator continued to run normally.
I double checked that the plug was assembled correctly and it was. Also there was zero evidence of any arcing or burning on the plug itself. None of the panel breakers tripped.
There was a 30 amp cord attached with a very light load.
I’m out on a road trip and maybe when I get back home I’ll take the panel apart and take a look for any arcing evidence.
Any ideas what may have happened??
2oldman
New Mexico
Posted: 09/05/19 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Have no direct answer, but just wondering why you made this bonding plug..?
Lynnmor
Red Lion
Posted: 09/05/19 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure that the generator was not already bonded?
SoundGuy
S Ontario
Posted: 09/05/19 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
All Honda EU series inverter generators have a floating neutral.
BFL13
Victoria, BC
Posted: 09/05/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
There is a duplex 15a receptacle and a 30a twist type. You used your bonded plug in one of the two 15a? but the 30a was occupied by whatever.
Ok, in a recent thread, it came out that there is something going on between the 15 and the 30 so they are not all the same wiring, so what you got was as though before you do all that needed work with the wiring in behind there, so when you bond a 15, it does not screw up the 30 --or whatever that was all about. ( It was complicated!)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/05/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
OK, let me understand: The Generator was running and then you plugged in your RV using the Neutral/Ground bonded plug? If that is correct, are you sure there wasn't something on in the RV that caused a surge of current when the plug made contact with the Generator outlet?
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Bobbo
Wherever I park
Posted: 09/05/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Check polarity of 30 amp outlet against 15 amp outlet, e.g. "hot wire to hot wire" should show zero voltage. If it shows 120v they are wired reverse from each other and one of them should be changed.
Triple check the bonding plug.
This only makes sense if both:
1. 30 amp and 15 amp have reversed polarity from each other
and
2. something in your RV has a neutral/ground short
The reason this would explain the problem is the RV's neutral/ground short puts one leg of power on the ground wire (the leg that is hot on the other outlet). The bonding plug puts the other leg on the ground wire. That is a dead short between the two legs through the ground wire.
Bobbo and Lin
Jetstreamer
Posted: 09/05/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I made the plug so I can utilize a volt/frequency meter without the alarm going off.
Jetstreamer
Posted: 09/05/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Anything is possible... the bonding plug was already in the generator outlet when I started it.
Jetstreamer
Posted: 09/05/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
and
Thanks.. The plug is correct and I’m just surprised that a breaker wouldn’t have tripped somewhere... Certainly could be something wired wrong...I doubt it from Honda it’s more likely that I’m wired wrong.... when I get home I’ll do some further inspection...
