RV.Net Open Roads Forum: Travel Trailers: Hotwater Heater
 > Hotwater Heater
RollandBC
BC
Posted: 09/05/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, ok with my furnace fixed it's onto the Hotwater Heater.
It's the manually lit pilot light.
This season I fired it up and after lighting the pilot and putting it in the ON postion, instead of a nice smooth burning BLUE flame its a wobbly weak orange light causing smoke and black soot at the exhaust.
Any suggestions
Ava
Vancouver Island. BC Canada
Posted: 09/05/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
The burner tube sounds like it is plugged. Bugs or dirt maybe.
beemerphile1
Ohio
Posted: 09/05/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Needs basic service like cleaning chimney and adjusting flame.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
RollandBC
BC
Posted: 09/05/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ok I'll pull the manual for it and run through a cleaning in the morning
drsteve
Michigan
Posted: 09/06/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Bug nest in the burner tube, most likely. Clean it out and you should be good to go. Resist the urge to poke anything into the gas metering jet. It is easily damaged.
1991 Palomino Filly PUP
Charlie D.
E. Texas-Orange
Posted: 09/06/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Had that on my heater. After cleaning it still happened. Finally found a wisp of a spider web in the tube.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
RollandBC
BC
Posted: 09/07/19 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Ok I managed to find time and got the tube out, a quick look and there was just 1 little wisper of dust.
Cleaned it out and used a soft brush on the fuel tip.
Fired up with a nice steady blue flame.
How long does it take for the water to warm?
RollandBC
BC
Posted: 09/07/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
I believe I found the answer >>
"While they can vary in size, the most common size of water heater is 40 gallons, which is what we'll be using here when talking about how fast they work. The bigger the heater, the longer they take to heat up the water. The average gas heater takes between 30 and 40 minutes to fully heat up the water in its tank"
westend
Shorewood, MN
Posted: 09/08/19 02:50am Link  |  Quote  |  Print  |  Notify Moderator
Typical RV water heater size tanks are 6 gallon, 10 gallon, and bigger for larger coaches. My standing pilot 6 gallon water heater takes about 10 minutes to fully heat the water.
'03 F-250 4x4 CC
RollandBC
BC
Posted: 09/08/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Yes this 1 took about 15 minutes.
Works good now!
Thanks everyone for your advice [emoticon]
 > Hotwater Heater
