RV.Net Open Roads Forum: Tech Issues: fresh water tank overflow syphoning tank dry
 > fresh water tank overflow syphoning tank dry
Goostoff
Wisconsin
Posted: 09/05/19 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
Let me start by stating that my overflow in a tube sticking out the bottom of the underbelly of the trailer. I have always just filled my tank untill water starts to flow out of the tube. It would always drain off the little bit that got in before I could pull the hose. For some odd reason this year when i do this the water will sit there and keep running out and will syphon the tank nearly dry before it stops running. Anyone have any idea what is going on. I'm thinking about installing a valve on the end but I fear that I would forget to open it and make even more problems
1993 Chevy C3500
2005 Cedar Creek 34RLTS
EV2
South Dakota/Arizona
Posted: 09/05/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
It can only siphon to the level of the opening inside of the tank. It sounds as though the tube is no longer at the top of the tank, but is now at the bottom.
shoprma
Fort. Collins, CO
Posted: 09/06/19 03:55am Link  |  Quote  |  Print  |  Notify Moderator
asdfghjkloingtbhfrgev
Lantley
Ellicott City, Maryland
Posted: 09/06/19 04:47am Link  |  Quote  |  Print  |  Notify Moderator
I have the same issue and I have valves on the ends of my vent and overflow pipes.
Yes you must remember to open valves.
Just make opening valves part of your setup routine
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
DutchmenSport
Indiana
Posted: 09/06/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Normally, isn't the overflow pipe also the vent pipe? If you close off the vent pipe with a valve, wouldn't that cause a vacuum in the tank and then nothing would pump out with the on-board pump.
Most tanks have a drain valve and an over-flow/vent. The end of the over-flow/vent is usually placed higher than the top of the tank, and installed in such a way that the direction is always upward, never down. Down could cause a vacuum in the tank.
Even if your tank is siphoning, there has to be a secondary opening somewhere to prevent the tank from vacuuming up, unless when you disconnect the water hose and the air is coming from there. Now, if you fill is gravity fill, then it does have the secondary opening to allow siphoning to occur.
So, I guess what I'm asking, are you sure that tube UNDER the trailer is not the drain valve and the vent is somewhere else? I've never heard of having the vent tube 'below' the object it's venting, only above it.
drsteve
Michigan
Posted: 09/06/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
What he said.
1991 Palomino Filly PUP
Bobbo
Wherever I park
Posted: 09/06/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I have never seen an overflow (actually vent) tube anywhere except right beside the gravity fill port. If you have a fancy trailer with levers to flip rather than a gravity fill port, I have no idea.
Bobbo, Linda and the furry kid (45 pound rescue)
Hondavalk
Toledo
Posted: 09/06/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
What he said.
What they said
Lynnmor
Red Lion
Posted: 09/06/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a gravity fill where you just stick in a garden hose? Does it have a vent next to it? Are you sure that the pipe expelling water is a vent? Is the trailer sitting level? Do you have a means of pressure filling the tank with a garden hose attached?
Lynnmor
Red Lion
Posted: 09/06/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Tens of thousands of RVs were/are produced with a pipe attached to the top corner of the water tank and then run out thru the bottom. No, they don't work, it is just a cheap way to get them out the door.
