RV.Net Open Roads Forum: Tech Issues: fresh water tank overflow syphoning tank dry
 > fresh water tank overflow syphoning tank dry
maillemaker
office
Posted: 09/06/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
My RV has a vent integral with the fill neck. The air is expelled from a little hole right next to the big hole for the garden hose. Inside the RV there is a small clear plastic hose that runs from the top of the tank to the vent hole.
My only problem is mold grows in that tube.
Steve
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
camperdave
northern, California
Posted: 09/06/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Only way I could see the vent line (that used to vent correctly) becoming a siphon is if the vent hose got pushed further into the tank further than it used to be.
Any chance you can physically get to and look at the fill/drain/vent lines on the tank?
2004 Fleetwood Tioga 29v
Lynnmor
Red Lion
Posted: 09/06/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Steve
It might not be your only problem, if you would be able to see inside the fill hose, you might not like what is in there. I had a clear fill hose on a trailer years ago that I replaced several times because of mold.
Those vents that are not inside a hatch door will collect rain water, wash water, dust and just about anything. My opinion is that they should have never been certified for a potable water system.
maillemaker
office
Posted: 09/06/19 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
My vent is inside the hatch door.
I'm sure the fill neck gets yucky, too, but it's black rubber so you can't see it. I suspect that it dries out well enough since it's so big in diameter. It's the little vent tube that stays damp.
The tank itself is clean (it's translucent so you can see it).
I don't worry about it though - we don't drink or cook with the onboard water. Just brush teeth. I sanitized the water tank once 10 years ago but have never done it since. I drain the entire system after ever trip.
Lantley
Ellicott City, Maryland
Posted: 09/06/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
My set up does not gravity fill. You can fill via a pressurized water hose or via a bucket using the on board pump. Filling is not a problem. I have a 80 gallon fresh tank,filling via gravity would be a PIA.
My overflow and vent tube both exit beneath the fresh tank.If you overfill the fresh tank a siphon will/can start. Once started the siphon can dump a lot of water on the ground.
iIhave resolved this issue by installing valves on my drain and siphon lines
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
Lynnmor
Red Lion
Posted: 09/06/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We need to quit calling a spill a siphon. The vent hoses are attached at the top of the tank and go down towards the road. If the trailer is tilted, water can spill out. If you round a curve and the water sloshes to the vent side, it will spill out. A siphon requires that the hose extend down into the tank, but that is not how they are made.
Adding valves to vents is both a miserable way to deal with a water system, and major damage can happen if one ever forgets to open them.
The proper fix for this cheap factory shortcut is to route the vent hoses up and out well above water level.
Lantley
Posted: 09/08/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
It's a siphon because once the water starts to flow it does not stop.
It's not a simple matter of the water spilling out.
I I overfill my tank enough to get water flowing out of the vent /overflow lines a siphon will start and continue long after I have stopped water flow into the tank.
I agree if the lines were run above the tank a siphon would not start, however for many of us the lines come out of the underbelly and siphoning is possible.
Lynnmor
Red Lion
Posted: 09/08/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have been thru this too many times before. It took some effort, but I convinced a manufacturer that the stupid design allows water to spill out, and they then changed to venting above water level. The reason that things never change is that too many have no idea how things work. Water runs down hill, it does not jump up to the top of the tank to find a hose.
STBRetired
I-80 and I-55
Posted: 09/08/19 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
There is no way the vents/overflows (I have 2) on my fresh water tank could ever siphon water from the tank. They are attached to fittings on the top of the tank and do not have any hose that extends into the tank. They might drip a bit on acceleration, braking, and turns. At most, I would say I lose a quart or 2 of water. Never enough to actually be noticed when looking at the tank.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Lantley
Posted: 09/08/19 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
I have been thru this too many times before. The reason that things never change is that too many have no idea how things work.
Is it up to the buyer to understand how to correctly pipe a fresh tank?
Do I need to submit my own drawings at time of purchase?
