RV.Net Open Roads Forum: Tech Issues: Norcold Fridge Issue - Help!
 > Norcold Fridge Issue - Help!
Donebee
Montana
Posted: 09/06/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Norcold 982 fridge issue. Fridge was running on AC, plugged in at home. Checked and found it was running on propane, C6 error. Replaced AC Heater and turned back on, set to auto. Seemed to run fine but after checking several hours later, find that it is again running on propane and displaying C6 error.
Checked internal control information, all appears within specs, except for AC Heater, which shows 1.5 amps, not 2.7 - 2.9 as listed in specs.
Did I get a bad new part?
drsteve
Michigan
Posted: 09/06/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
C6 code means AC heater open...
Clicky
1991 Palomino Filly PUP
Donebee
Montana
Posted: 09/06/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I am aware of that, which is why I replaced the AC Heater with a new part.
maillemaker
office
Posted: 09/06/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the new element burned up. Either you got a bad one, or something is wrong that is burning up elements.
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
Donebee
Montana
Posted: 09/06/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I'm hoping it's a bad element; the last one worked for the five years I've owned the motorhome without any issues.
enblethen
Moses Lake, WA
Posted: 09/06/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
I would check for output from the circuit board. The circuit board is looking for resistance of the element. It is possible that the relay is bad on the board. you could wire up a standard 120 volt lamp socket with lamp and connect to output of the circuit board to simulate.the element. If thelamp does not light up, the circuit could be at fault. 60-100 watt incandescent lamp should be sufficient.
Measure your replacement element for resistance across the leads. No resistance means it is open and bad.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wnjj
Cornelius, Oregon
Posted: 09/06/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
ohm the element out. If the spec is ~2.8A you should read ~43ohms. (120V/2.8A = ~43ohms).
If the element is ok, there is extra resistance from somewhere else including wires, connections or the relay.
The relay in our 621 failed but more drastically. I replaced it for less than $6 (http://www.rv.net/forum/index.cfm/fuseac........d/29727778/gotomsg/29741786.cfm#29741786)
Donebee
Montana
Posted: 09/11/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Okay, I turned off the fridge and let it sit overnight. Tested the new, recently replaced AC Heater and it tests at 44 Ohms. I'm thinking about turning the fridge on, waiting for the element to fail, as it seems to run on AC for 30 minutes or so before it fails. and then ohm it out again once it fails. Perhaps it's failing after the element begins to heat?
enblethen
Moses Lake, WA
Posted: 09/11/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Did you happen to test your old element for resistance?
Sounds like it is the circuit board
Donebee
Montana
Posted: 09/12/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I did. It had indeed failed. Not that it can't be the circuit board, but it was replaced less that one years ago.
