RV.Net Open Roads Forum: Truck Campers: mounting air fitting for air bags
 > mounting air fitting for air bags
burningman
Seattle, WA USA
Posted: 09/06/19 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
You can add the compressor and I highly recommend it.
I ran bags for a few years without, and it kinda’ sucks. There’s never air when and where you want it and if a bag leaks down a little you can’t fix it.
Having buttons to press to adjust your suspension on the fly, any time anywhere is pretty great.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
Buzzcut1
Norcal
Posted: 09/06/19 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have both of mine on the bottom of the passenger side of the bed just behind the cab. I did it for two reasons. I don't ever want to be standing on the traffic side of the truck to add air. I don't trust other drivers. Secondly I routed the air lines inside the frame rails and away from the tires so that a blow out will not rip out the air lines. Yes that happened on my first set up.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
otrfun
On The Road
Posted: 09/06/19 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
In lieu of trying to find air somewhere, or installing a compressor, we carry a high pressure bicycle pump (100-150 psi) with us. We can pump up a 5 psi bag to 30 psi in less than 30 sec. Not for everyone, but it works for us [emoticon]
specta
utah
Posted: 09/07/19 05:25am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advise.
I'm installing them today and will post a picture of where they end up.
Kenny
2011 Chevy 2500 HD 6.0L 4wd Regular cab.
What real trucks really look like.
6580 lb truck 10540 fully loaded
bigfootgrey
Connecticut
Posted: 09/07/19 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Mine are inside the fuel door. Stays clean and protected
Bob
2011 Ford F-350 PSD SC DRW
2008 Bigfoot 25C-10.4E
Firestone airbags - torklift stable-loads,fastguns,Talons Rancho rs 9000XL’s. 2015 Lund Alaskan 1600 tiller.
specta
utah
Posted: 09/07/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Bob
I'll have to see how much room I have in there.
Kayteg1
California > Nevada
Posted: 09/07/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
When on-board compressor is luxury, having valves with gauges on the side of driver seat, I could always see the pressure when entering the truck.
Than my bags would hold the air for months, so unless I load heavy, I did not have to inflate them for long time.
Than when I did need to air them, one of those $10 compressors did the job in just minute.
Get the console with gauges and you won't be sorry.
toddb
az
Posted: 09/07/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I made a bracket that uses the bolts from the running board. It's out of the way behind the rear door.
ajriding
st clair
Posted: 09/07/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Originally put them as the license plate bolts, which was perfect, except not for a TC as it is hard to get to then.
I then put them on the bottom of the rear fender behind the wheel by drilling a hole under it. This is OK, but I rather have the two valves together. There is no need to have them on both sides of the truck.
I was worried about using the inside fender well in case the tire threw something up to damage the valves poking out. I have a fender well plastic liner, so the valves would have to be inside the well…
northshore
northshore
Posted: 09/07/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I put them just in front of the rear wheel DRW under the fender, easy to reach.
I had a Firestone compressor but removed it, didn't like it, plus it was for one supply line to both bags. My compressor came with the in cabin bracket, with switch and gauge, that with all the other stuff hanging on the dash I thought it was just too much. Now its; set the air pressure for the bags where I want them and check once in a while, I don't feel the need to have a switch and gauge on the dash.
