RV.Net Open Roads Forum: Service, landing gear down, or while still hooked to truck?
 > Service, landing gear down, or while still hooked to truck?
MFL
Midwest
Posted: 09/07/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
In the past, I normally stay connected to my truck, when raising the axle slightly, to adjust brakes, or do bearing work. My thinking was less stress to the frame and landing gear.
I am going to do some servicing over several days, and would like others thoughts about raising axles, one side at a time, just enough to remove wheels, with the landing gear down. Have I been overly cautious in the past, or do you think this may stress landing gear and frame?
Appreciate others opinions,
Jerry
RAS43
Littleton,CO
Posted: 09/07/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I always do that job with the truck hooked up and the legs raised off of the ground. I believe that eliminates side stress on the legs and doesn't stress the truck or hitch.
DutchmenSport
Indiana
Posted: 09/07/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Why not play it safe and get some jack stands to support the 5er. Use the on-board jacks to raise it, then lower on jack stands. Then you can leave the 5er on the stands as long as you want, AND have the truck free. FYI, this was one of the better investments I've made recently.... Harbor Freight ...
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/07/19 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I feel better with the RV connected to the TV while servicing the suspension. While not likely there is always the possibility of the landing gear failing, no chance of the TV failing.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
MFL
Midwest
Posted: 09/07/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies! I plan to rebuild my wheel wells to make them more water proof. I try to avoid towing in the rain, as the nylon Darco covering has a few holes, with fiber insulation above, and then floor above that. I plan to use 2" extruded closed cell foam insulation, a layer of foil faced bubble water proof insulation, and cover all with 4mm coroplast.
This project will take a while, as I have other daily obligations that take me off the job. It would be nice to not tie up the truck, being connected for 3-5 days, but seems others feel like me...best to leave connected, landing gear up.
Any other thoughts/replies appreciated,
Jerry
Old-Biscuit
Verde Valley
Posted: 09/07/19 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Landing gear is fully capable of holding the front of trailer w/o straining
Repair shops work on 5vrs while sitting on landing gear all the time
Jacking up a wheel enough to remove tire is only compressing the suspension and does not twsit the frame
Tying up the use of ones truck is NOT necessary.
Use of jack stands is great for working ON landing gear.
azdryheat
Tucson, AZ
Posted: 09/07/19 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
When I work on my trailer, when needed, I put all 6 jacks down to raise the tires off the ground. Did that today as I'm changing the suspension from Equa-Flex to E-Z Flex. I still use jack stands under the axles to be safe.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
ksbowman
Kansas
Posted: 09/07/19 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with Old-biscuits thought. I changed axles with the landing gear and jacks with jack stand supporting the weight. Very stable and I had mine up several days.
Tom Cooper
New York
Posted: 09/08/19 03:19am Link  |  Quote  |  Print  |  Notify Moderator
This is a rather sensitive topic. It seems to be doing everything right, but the jack once bent the chassis to me. It was very disappointing
JIMNLIN
Oklahoma
Posted: 09/08/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I never leave the truck hooked to the trailer while I'm working on it.
While doing brake work or just changing a flat while my rv trailer....bumper pull trailers....stock trailers....GN equipment trailers....cargo trailers sits on the concrete pad in front of my garage I use a hyd floor jack under the axle tube next to the U bolt on a std leaf suspension and lift just enough to remove the wheel. Nothing gets stressed...bent...crushed....twisted by doing so.
Out on the road or sitting in a campsite I use my trusty old 12T shorty hyd jack 1978 Trucker Special with a 10" X 10" base in place of the floor jack doing the same.
* This post was edited 09/08/19 06:13am by JIMNLIN *
