RV.Net Open Roads Forum: Service, landing gear down, or while still hooked to truck?
 > Service, landing gear down, or while still hooked to truck?
MFL
Midwest
Posted: 09/08/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the added thoughts and opinions! I think I'll try it disconnected, as I'll only need to raise the axle about two inches to remove tire/wheel, while doing one side. I'll use my 8" high wood blocks under landing gear, so I won't need to use much of the landing leg extensions.
I jack under a U-bolt, using a hardwood 2x4 that is cut out, to just fit one of the U-bolts. I have a rubber padded jack stand to put under the axle tube near axle end. My axles are 5200 lb, and seem robust.
Jerry
FlatBroke
CO/AZ
Posted: 09/08/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
I got 48 hours to service my trailer in front of my house. Code says it Must NOT be unhooked.
Hitch Hiker
"08" 29.5 FKTG LS
garyp4951
TN
Posted: 09/08/19 08:25am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Thanks for the replies! I plan to rebuild my wheel wells to make them more water proof. I try to avoid towing in the rain, as the nylon Darco covering has a few holes, with fiber insulation above, and then floor above that. I plan to use 2" extruded closed cell foam insulation, a layer of foil faced bubble water proof insulation, and cover all with 4mm coroplast.
This project will take a while, as I have other daily obligations that take me off the job. It would be nice to not tie up the truck, being connected for 3-5 days, but seems others feel like me...best to leave connected, landing gear up.
Any other thoughts/replies appreciated,
Jerry
Jerry, I have to do the same thing, my new FW just has the black tarp looking material in the wheel wells, what a stupid thing for manufacturers to do.
I'm thinking of using the pvc material sheets at Lowes for bathrooms on mine.
Cummins12V98
on the road
Posted: 09/08/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Jerry this item works wonders!!! I have done maintenance and road side repair with this wonder.
TrailerAid Plus
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MFL
Midwest
Posted: 09/08/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Yes Gary, while that Darco actually is pretty rugged, a rock, stick, or flying road debris will cause a puncture. Wouldn't matter so much, but with fiber insulation above, getting wet, could lead to flooring issue.
Jerry
MFL
Midwest
Posted: 09/08/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
TrailerAid Plus
Yes Ron, those work great for a lot of uses. I like my trailer aid plus, especially for brake adjustment, as then there's nothing in the way to use brake tool. I've used it once in an emergency road side issue. Nothing quicker, to get her done, on a busy interstate.
Just not going to work, if I do it at home, truck unhooked.
Jerry
Cummins12V98
on the road
Posted: 09/08/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
You just don’t have room to leave truck attached?
MFL
Midwest
Posted: 09/08/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, I bought as big a FW as I could, to keep at home 31' OAL. This allows 4"s from garage eve, and pin box right at edge of public sidewalk. I put my MC trailer tongue under FW, and other end under pin box, so no one can possibly hit their head.
Truck connected...across side walk, apron, and in street. I may want to remove both wheels, same side, for best access.
If I leave truck connected, it would be at a shop a couple miles away, so not so handy.
Jerry
Braces
Alabama
Posted: 09/09/19 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
If you add 2" to the inside of the wheel well you might face the possibility of the tires hitting the wheel well on some of our nice, smooth, no bump roads. Happened to me when I went up a little on tire size and hit a really rough road section.
MFL
Midwest
Posted: 09/10/19 05:26am Link  |  Quote  |  Print  |  Notify Moderator
You are correct...taking away 2"s of clearance in the well, would not work in most cases. I will be replacing, not adding. My FW is designed with a 6 sided 2.5" square tube aluminum cage. I will slice the Darco wrap that covers bottom of tubing, remove existing fiber insulation, replace with above mentioned, glue Darco back to solid insulation. I will be adding 4mm thick coroplast over the fix. I will still have nearly 3"s of tire to WW clearance as 4mm (a long 1/8 inch) is all that will be added.
My question/concern was raising the axles to remove tires, with the landing gear down, not connected to truck, causing stress.
Jerry
