RV.Net Open Roads Forum: 2020 Freightliner vs 3500 GMC Dually at the Ike
Search only in Tow Vehicles
 > 2020 Freightliner vs 3500 GMC Dually at the Ike
Page of 5
FishOnOne
The Great State of Texas
Posted: 09/07/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Interesting outcome...
Trailer: 18,500 lbs
GMC
Engine: 6.6 Duramax
Brake Applications: 1
Time: 10:28
Freightliner
Engine: 9.0 Cummins
Brake Applications: 0
Time: 10:42
Link
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
4x4ord
Alberta
Posted: 09/07/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Measuring the time required to tow a trailer up a hill is an accurate method of measuring rear wheel hp. It surprises me that the GM didnt smoke the Freightliner.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
bguy
The Rock
Posted: 09/07/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
What percentage of each vehicles towing capacity is the trailer at that weight?
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
gmw photos
midwest
Posted: 09/07/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
And how close is each to the rear axle weight rating ? This is a perfect example that "payload" is primarily a registration class derived number. This Freightliner is likely capable of being registered up to class six.
4x4ord
Alberta
Posted: 09/07/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
They praise the performance of the engine brake on the Freightliner over the performance of the exhaust brake on the GMC, however, if more weight had been loaded into the trailer the Duramax would have held 50 mph yet the Freightliner would have required additional brake applications. Comparing two trucks on one hill with only one weight in tow doesn't really offer an honest comparison. I'm having trouble understanding why the GM slowed down as much as it did going up the hill ..... something doesn't add up. Even back in 2015 (with 396 HP and 765 lb ft) the Duramax towed 19000 lbs up the Ike in just under 10 minutes. link
* This post was edited 09/07/19 10:52am by 4x4ord *
Posted: 09/07/19 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Duramax FTW!!!
noteven
Turtle Island
Posted: 09/07/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Anyone know what the gross weight of each combination was?
Also when the pickup goes into downshift run to the governor upshift nope can’t pull it downshift try again upshift nope can’t pull it mode why not select the lower gear and let it pull near its max power rating, like a truck driver does it?
* This post was edited 09/07/19 10:55am by noteven *
Posted: 09/07/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
4x4ord wrote:
They praise the performance of the engine brake on the Freightliner over the performance of the exhaust brake on the GMC, however, if more weight had been loaded into the trailer the Duramax would have held 50 mph yet the Freightliner would have required additional brake applications. Comparing two trucks on one hill with only one weight in tow doesn't really offer an honest comparison. I'm having trouble understanding why the GM slowed down as much as it did going up the hill ..... something doesn't add up. Even back in 2015 (with 396 HP) the Duramax towed 19000 lbs up the Ike in just under 10 minutes. link
**** man....that new Dirtymax driver is a sand baggin bisnatch then! He must have stock in Freightliner!
ShinerBock
SATX
Posted: 09/07/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Looks to me that the GM de-fueled and/or ****** timing (cutting power) because EGT's were probably getting too hot. Big difference between initial power and sustained power.
The GM's 445 horsepower is barely sustainable towing that heavy of a load with a stock turbo in a deleted truck without getting the EGT's too high so I doubt an emissions intact truck can sustain that. It would have to de-fuel/****** timing to keep the EGT's in check.
* This post was edited 09/07/19 11:33am by ShinerBock *
4x4ord
Alberta
Posted: 09/07/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
ShinerBock wrote:
Looks to me that the GM de-fueled (cutting power) because EGT's were probably getting too hot. Big difference between initial power and sustained power.
The GM's 445 horsepower is barely sustainable towing that heavy of a load with a stock turbo in a deleted truck without getting the EGT's too high so I doubt an emissions intact truck can sustain that. It would have to de-fuel to keep the EGT's in check.
You may be right but isn't it surprising that the 2015 Duramax out performs the 2017? I would have thought the turbo on the 2017 would pump more air and be capable of higher power with lower EGTs.
Page of 5
