RV.Net Open Roads Forum: Travel Trailers: Anode rod necessary ?
 > Anode rod necessary ?
dougbo4
south jersey
Posted: 09/07/19 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I only use my 22ft travel trailer on weekends, 2 or 3 nights. 6gal water heater. If I drain my hot water tank after every use, is an anode rod really necessary ?
JRscooby
Indepmo
Posted: 09/07/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
No, you can let the tank desolve. Maybe a short nipple, a "Tee" and a valve at the bottom of tee?
ScottG
Bothell Wa.
Posted: 09/07/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I would keep the anode and leave the water in the tank between trips. Do it for the same reasons you dont drain your home WH when you leave.
Also, unless you suck the water out, even after you drain it there will be a puddle in the bottom. That water will work on eating the botom of the tank since the anode isn't in-play.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
cavie
Posted: 09/07/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, your tank is coated steel. Anode rod gets attacked instead of your tank.
BarneyS
S.E. Lower Michigan
Posted: 09/07/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Kind of depends on the maker of your heater. If an Atwood, then no anode rod is necessary.
If a Suburban, then I would use use one because eventually the inside will corrode due to the water being present, even if only part time. The one that comes with the Suburban should last quite a long time though. Just inspect it when you pull it out to drain the heater. When it gets to looking like a rough piece of thin pencil then replace it.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
treyster
Ohio
Posted: 09/07/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I bought one of those Anode rods with a petcock in it. Works reasonably well
ScottG
Bothell Wa.
Posted: 09/07/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Deleted
ksg5000
Oregon
Posted: 09/07/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Barney
x2.
Kevin
Old-Biscuit
Verde Valley
Posted: 09/07/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
What about during the time you are USING the water heater?
What do you think anode rod is for?
YES ------ if it is a Suburban Water Heater the anode rod is Necessary.
dodge guy
Bartlett IL
Posted: 09/07/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. For the small price of the anode rod keep it. I have gone as much as 3 years on one anode, very little damage. It only dissolved at the end of the 3rd year.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
