RV.Net Open Roads Forum: Main power extension cord now a must for me
 > Main power extension cord now a must for me
imgoin4it
Alamogordo, NM USA
Posted: 09/07/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a 25 foot 50 amp extension cord. It used to be 30 feet cord with a 50 amp plug until I drug it about 15 miles down an interstate highway. A little shorter but turned it into an extension.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
pianotuna
Regina, SK, Canada
Posted: 09/07/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly why I use an autoformer.
Boomerweps wrote:
75'! 125'! Great Googly Moogly!
MASSIVE voltage drop!
Yes, it was a private CG.
Regards, Don
SoundGuy
S Ontario
Posted: 09/07/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Boomerweps wrote:
Last camp, the power pedestal for my site was too far away for my 30' mains cable.
I needed between 15-20' to reach.
Boo Hoo - here in Ontario, when camping in the provincial park system, 100' to the power post isn't unusual at all. I have 140' of 10 gauge and have used every bit of it on occasion.
ScottG
Bothell Wa.
Posted: 09/07/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
cougar28 wrote:
ScottG wrote:
Old-Biscuit wrote:
With DUAL 50A Receptacles Front & Rear and detachable 50A Power Cord I have NOT needed an extension cord
How do you switch between them?
He saying he has a receptacle that common between the two on his. One in front and one at the rear so he just uses the closest one to the power pedestal to plug his cord into.
Thx, I knew what he was saying. Problem is, if you're plugged into one and there's no switch to select between them, the other will be hot and present an electrocution danger.
That's why I asked.
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
GordonThree
Northern Michigan
Posted: 09/07/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
That's why I asked.
Scott
I was thinking the same thing, sounds dangerous.
Of course, locking covers maybe?
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Old-Biscuit
Verde Valley
Posted: 09/07/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
The 2 AC Source Inputs went to an Auto Transfer Switch \
The ATS were troublesome (Parallax)....both failed and Parallax knew of problems. Wanted to keep sending me replacements.... [emoticon]
I threw the junk away and installed a 125V subpanel wired up the 2 AC Source Inputs to 50A CBs that are mechanically interlocked so only one AC source can be On at a time.
Need a part........50A CBs available at any hardware store. No more troublesome relays/contacts etc.
Just a simple manual transfer by flipping the CBs
pianotuna
Regina, SK, Canada
Posted: 09/07/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have a permanent extension cord #10 with a male end at the front of my RV and a female at the rear. I simply plug the Shore power cord into the female outlet. That lets me power the RV from either end safely.
CA Traveler
The Western States
Posted: 09/07/19 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
So you plug in shore power to the female outlet and the male end of the permanent extension cord is now hot? There must be more to the story.
2014 Grand Cherokee Overland
Bob
ScottG
Bothell Wa.
Posted: 09/07/19 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
I knew it would be above-board! [emoticon]
Old-Biscuit
Verde Valley
Posted: 09/08/19 12:35am Link  |  Quote  |  Print  |  Notify Moderator
No 'widow maker' cords for me!
